Question about Garmin Rino 110 (14 Channels) 2-Way Radio
Unit will not stay on. With new batteries installed, the unit turns on while power button is held down. It immediately turns off when power button is released. The batteries have never lasted long.
  • Garmin Master
  • 1,654 Answers
If using rechargeable batteries, your batteries are not getting charged. Check your charger, battery contacts and batteries. Clean contacts with a pencil eraser.
If using alkaline batteries, check placement of the batteries to be certain they are in the correct way, and also, clean the battery contacts.
Posted on Sep 08, 2009
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power...
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Sep 07, 2010 | Toshiba Satellite M100 Notebook
Cannot reset Tom Tom ONE 130. Have held down power button to no avail. Used only 2 times. Battery charged
There is a small hole near the docking base , insert a pin to reset the unit. Holding down the power button will never reset the unit.
Hope this helps. thanks
Aug 11, 2010 | Tomtom ONE 130 GPS Receiver
The beeper on my HP Officejet 6210 All-in-one unit is on all the time on or off with power button. The only time the beeper stops is when it is unplugged from the wall outlet. I got an auto reply to try to...
I want you to try NVM (Non Volatile Memory) reset for this printer. Perform the printer is connected directly to wall outlet with now Surge protectors.
Steps:
  1. Remove the ink cartridges.
  2. Disconnect the power cable from back of the printer while its ON.
  3. Press and Hold OK and CANCEL button, while holding the button insert the power cable and continue holding it for 20 seconds
  4. Printer will turn OFF.
  5. Turn ON the printer and insert cartridge when it prompts.
Regards,
Rizwan.
Jan 20, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
Will not power on-- batteries are new- if pwr
Hi:
I was using one of these for the last 8 months, and mine did the same thing, I would push power and the unit will just blink the lights then shut off, But if I hold the power button the light will stay on until the button was released, so I contacted Solo Tech support and they told me the system control board was bad, and in order to get a new board I had to be an authorized servicer for then, I found the board online and the price for the board exceded the price I paid for it. So i deemed it necessary to just purchase a new Scanner....
Dec 27, 2009 | Solo S2 Radar Detector
My GPS won't stay on
I can solve this by not solving it. First I tried reset the unit to default settings: hold down the power, page, and enter buttons at the same time, a message, "do you really wan to reset..." will appear. Select "yes." If the unit reboots, hurrah. If not, call tech support (1.800.800.1020). Get an RMA, send it back to them for repair. I had purchased mine over 30 days ago but less than 60: Amazon wouldn't replace it, Garmin will either replace or repair. If you want them to send a new unit while the old is in transit, just ask; they will charge and then credit a card once they have the old unit is in hand. Good luck.
Apr 25, 2009 | Garmin eTrex Venture HC GPS Receiver
Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Mar 17, 2009 | Brother HL 5250DN Laser Printer
Replaced lamp in optoma ep1690 but there is not projection
Hello, many of times this is related to the brighter being turned down and we go about trying to turn up the unit thru the remote and you may need to do this adjustment directly from the panel on the unit.
If this should fail, you may need to unplug the unit and allow it to be off for over 24 hours and this will cause the unit memory to return back to the manufacture's settings and if you still get the same result, consider your lamp may have played out, need to be replace... good luck and I hope thi helps.
Jan 23, 2009 | Televison & Video
IPAQ 3765 Won't Turn On
you may have to buy a new battery for the unit. Simple as that
Jan 05, 2008 | Compaq iPAQ H3850 Pocket PC
Garmin Rino 110 (14 Channels) 2-Way Radio Logo
145 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
