Question about Dryers
THERE IS NO HEAT IN MY WHIRLPOOL DRYER MODEL LEQ9030PQ0
    Brigadier General:
  • 4,088 Answers
Check the dryer twin breakers in the house electrical panel--push off, then on. If breakers hold, then try the dryer again. If it heats, you are good to go. If it trips the breakers again, there is a direct short in the dryer itself, usually in the heating element(s). The drum must be removed to access the element(s).
Posted on Sep 07, 2009
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
Whirepool electic dryer leq9030pq0 will not heat up I replaced thermal switch and cut off. only switch not replaced has 2 purple wires going to it. How to tell if coil is bad
The heating element should read between 9 to 13 ohms if good. You need to disconnect the leads to ensure you don't read any parallel resistance paths. In addtion, you may want to pull the element from the heater box and physically inspect the coil for breaks.
Jun 25, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LEQ9030PQ0 electric will not start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Jun 03, 2009 | Whirlpool LER4634J Electric Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
No heat
Hello, Im Mark and im highly trained in whirlpool dryer repair. Here is my Site. Whirlpool Dryer Parts. Anyways i would need to know what model your whirlpool dryer is, and the model number. Then from there it is a breeze. Simply give us a call and we can have you up in no time.
Mark
Apr 14, 2009 | Whirlpool Dryers
No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
ELECTRIC DRYER WILL NOT HEAT
Can you verify model number, it usually starts with WE
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Dryer Won't heat
tested the thermal fuse inside back of dryer??? if so id check the heater and 2 other thermstats right there on back wall behind panel
Mar 15, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
238 people viewed this question
Top Dryers Experts
