Question about Toshiba 42H81 42" Rear Projection Television
When I first turn on my TV, I get horizonal faded lines
When I first turn on my TV, I get horizonal faded semi transparent lines. Then after 1-2 minutes of warmup they go away and everything is fine. are the red/green/blue electron gun starting to fail? Thank you, Robert
  • 80 Answers
It probably has leaky capacitors in the hyper board or the video process board, this repair requires a qualified tv repairman, you can't do it yourself, alot of actual repairman can't handle this repair. it will get progressively worse as time goes on the more leaky the capacitors become.
Posted on Sep 07, 2009
How to fix blue line appearing on my tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 02, 2016 | LG 42LM6200 42 in. 3D LCD HD Cinema Smart...
FX500 Parallel lines semi transparent / ribbed effect
hi there i have the same problem did ytou get it repaired, what was wrong?
Sep 13, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
My older Toshiba TV is showing horizonal lines on upper screen.
maybe dust in the back of set try giving it a hoover out but unplug first
Mar 19, 2009 | Toshiba Televison & Video
Philips tv
You have bad capacitors in the vertical sweep circuit. If you have no electronic repair experience, you will have to take the set into a repair shop as these parts are soldered into a printed circuit board and need to be tested with an ESR cpacitor meter. Good luck
May 26, 2008 | Philips 32PT5441/37 32" TV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Toshiba 42H81 42" Rear Projection Television Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
