Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE PSS26SGPA SS Side by side Fridge Fridge makes ice but will not dispence water. Water filter is new (less than 1 month) and worked great after the filter swap. Checked the valve and line from the wall to the fridge and water flows fine. Also checked to make sure the water line in the bottom door hinge was not pinched.
Master_Tech
  • 770 Answers
SOURCE: GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Posted on Mar 15, 2008
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
SOURCE: GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Posted on Jul 30, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
tborn6
  • 700 Answers
SOURCE: GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Posted on Apr 03, 2009
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
I HAVE A SAMSUNG SIDE BY SIDE FRIDGE. WHEN DISPENSING WATER, THE WATER VALVE HAS AN EXTREMLLY LOUD VIBRATION. HAD THE FRIDGE FOR 6 MONTHS AND IT JUST STARTED DOING IT.
check to make sure the filter is clean and as in most cases there are 2 electromagnetic solendoid valves in the back of the fridge..lower right corner which dispences water to freezer for ice and to the door for H2O. Hope this helps..Jarhead
Oct 30, 2013 | Refrigerators
ED25DWXTN01 AFTER DISCONNECTING AND MOVING TO A NEW LOCATION I CANNOT GET WATER FROM DISPENSOR OR WATER UP TO THE ICE MAKER IS THERE A WAY TO BLEED THE SYSTEM?
In effect the only thing different is you moved the fridge and switched the water off. Make sure the water is getting to the fridge pipes connected to the fridge valves.(normally blue in colour.). If not rectify problem. If water is there, suggest you remove water filter in the fridge compartment and by pressing the water dispencer button see if water runs out at the filter adaptor. If not, there is an issue with the solonoid valve/s (very unlikely thougf) Could very possibly be the water is frozen and needs defrosting. Because there are variables that i havent been given, im surmising a lot. Normally when you depress any of the dispencing buttons,a clicking sound will be heard from the solonoids at the back. Simply the water should flow up the pipe to the filter then to the dispencer outlets. Most of the time, the water is either off or filter is blocked or limit switches at dispenser end is faulty. Very unlikely that both are defective at once so check the filter and water supply. If stuck, email me on terfou@imaginet.co.za
Sep 03, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
I have a GE side by side stainless steel refrig. the water will not dispense. How can I fix it?
Is there water to the water valve in the rear of the fridge? If yes, replace the water filter if older than 6 months or if you're on a well. You may need an inline water filter behind your fridge in addition to the one in the fridge to protect the water valve. If no, turn on the water. If you're making ice but no water dispense and you have a new water filter. Replace the water valve.
Dec 10, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Ge fridge 1
is looks like you need to trouble shoot *********** board is this unit has one i can see if i can fix it for you bu i need more info how old is it is it side by side let me know call 562-688-3627
Sep 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
720 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
