Question about Tomtom ONE GPS Receiver
When powered on all i get is two hands with a big red X thru them - tried the manual reset and have had no luck.
  • 3,153 Answers
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Posted on Sep 08, 2009
I have a invicta bolt zeus and it stopped working. When I reset all the hands everything moves except the subdial that reads the seconds. Even when the big second hand moves the subdial doesnt. Also even...
If you suspect the battery try some spare batteries double checking with several known good to brand new one tests to cover your bases for consistency. It is a method of trial and error eliminating any possibility of a battery problem.
Sometimes there are power drain issues where cheep batteries even new can't handle. Trial and error illumination of a power drain issue checking with high power drain capable batteries. Information can sometimes be found in the manual in the specification.
From there you have the insight information it is not the battery in your further investigations describing the problem to a dealer or manufacture.
Other options of investigation include if you have the owners manual to check if there is any special settings to instigate you may need to know about dealers and the manufacture should know as well.
Dec 19, 2014 | Watches
Jvc kd bt11
hi vicki, firstly check out the power wiring to your unit. yellow wire to the battery +12v(direct live) and the red one to the ignition switch(vehicle start switched live). also try resetting your unit. if all these donot work then check out your local installer before handing the unit in for repairs. good luck. cheers.
Sep 06, 2013 | Car Audio & Video
Picture too big for screen.
My Sony KDF E42 remote has a "wide" button that lets me scroll thru normal, zoom( too big), wide, and wide zoom. If yours has a simmilar button, try that. Otherwise try Googleing the owner's manual buy brand & model. Good luck.
Jun 21, 2009 | Sony KP-46WT500 46" Rear Projection...
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Ink Error "Check Ink, U051, BLK COL"
power off
press hold red button
power on hold button
release red button twice
=beep=
all done !
Mar 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Electrolux powernozzle not working
mine was the power head neck itself the handle got twisted to far and broke the wire a new neck cost 37 bucks online and i installed it myself wires get attached color to color and screw the head back together. it worked just like new!
Mar 18, 2009 | Electrolux Centralux Vacuum
Water filter
the filter is located in the upper left hand corner of the fresh food compartment there is a thumb latch that you press then a cover comes down and exposes the filter turn 1/4 turn counterclockwise and it will release the part number for the filter is 9990 and is available thru sears.com you can also get your manual there as well. good luck peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Switching on the tele this morning, the normal blue background is now half red and half blue.....(top half red) so that while watching a program now people have green faces.......weird!!
Good Day, deejay268;
Try resetting the entire system by unplugging the tele and the boxe. Unplug from power source for 3 to 5 minutes, then re- connect. Good Luck, big IRISH.
Sep 01, 2008 | Televison & Video
Resetting GMT hand
I have CL1180 and had the same problem, pulling the winder out to position 2 (fully out) and using the buttons resets the second and 10th second hands and putting the winder in position1 and using the buttons does the same for the minute and hour hands. However finding position1 was tricky, only seems to work on the way out from fully home and not on the way back from pos 2.
Hope that helps.
Apr 08, 2008 | Tag Heuer Aquaracer Quartz Chronograph...
RCA Red P
Try hard reset==leave unplugged from AC overnight.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tomtom ONE GPS Receiver Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
