Question about HP Compaq Presario V2000 Notebook
File transfer with Dynex cable
Compaq V2000 w XP and new Compaq 6910 w Vista. Data transfer problems. I have a Dynex Easy transfer cable. One end is a flash drive w the software. New Vista downloaded it, old XP refused.
For XP I downloaded a plug-in from MS.com. It will not install
the plug-in. No matter what I try, the 2 puters wont see each other.
  • socal92504 Sep 09, 2009
    I did try hooking up the Dynex cable again and for whatever reason, this time XP accepted the software download. After that the tranfer went fairly easy. The Dynex cable has a regular USB plug on one end, the other end is a Flash drive with the software.
    Thanks for your help.
  • 3,153 Answers
USB transfer cables are quite special and not a regular USB cable.
A better (and cheaper) option is if both have network ports (Ethernet)
Then use a crossover cable. This is usually much much faster than USB and also more reliable.
Enable file and printer sharing on both computers.
Also make sure they both share the same work-group common examples are MSHOME or WORKGROUP
Once that is done you have a few options.
The better option is to use file and settings transfer wizard or similar built into windows. This will step you through the process and allow you to carry over your email and address book plus all your documents.
Another is to use copy and paste to pick the items you want and move them directly to where you want them (his does not work as well as the FST option but is quick just for documents etc.
Dont try to copy programs as they don't transfer well for the most part.
If usb is your only option then be very aware that USB 1.0 to any USBwill be extremly slow and even subject to failure. USB 2.0 to USB 2.0 is the only reccomended usb transfer method
Posted on Sep 07, 2009
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Have been using Mozilla Thunderbidr for email. Have a new computer and have Mozilla Thunderbird seet up there - would like to be able to transfer old emails (kept for reference) to the new computer. Have...
Now-a-days the storage space of an email provider is so huge that you can access them using any PC with internet unless you have deleted from the server. If so transfer all emails to a separate HDD, load your new OS and transfer the data back......................sodeep
Sep 24, 2009 | Dell Dimension 4600 PC Desktop
Transfer files from old laptop to new.
Sep 07, 2009 | Compaq Computers & Internet
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Usb transfer files doesn't work
this cable is design to transfer files from xp to vista or vista to vista.
but you can try by installing the software on both the pcs and tranfer the files hope it will work
Mar 23, 2009 | Compaq Computers & Internet
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Dynex Easy Transfer Cable isn't working
You only need to install the CD stuff on your Windows XP computer. It installs automatically for Vista when you plug the cable in. This cable only works for transferring from an XP computer to a Vista computer.
Oct 24, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
1,735 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
