Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
I NEED T TAKE MY EXTTERNAL DRIVE APART - SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
    Sniper:
  • 58 Answers
Check if it is in use using Task Manager (Ctrl+Shift+Esc)
Single click on the USB icon in the right side bottom corner (System Tray) and select Safely remove hardware
Posted on Sep 07, 2009
My system is not displaying but still work what to do pls
Your question seems tricky , if there is no screen display how does it work? however if there is display when you connect to an extternal monitor then the fault seems to be with the LCD. it can failure of the back light circuit- the inverter drive or it can be a fault in the line to the display through the hinges or the failure of the LCD/drive.
Oct 26, 2011 | Toshiba Satellite P105-S6197 Laptop
My computer will not let me click on any thang how do i fix it
Please specify or . format the computers and install operating system again
Apr 20, 2011 | Computers & Internet
How can you manually eject a game for the disk drive, if the normal eject method does not work?
Hi their is no easy way im afraid you have 2 options either let a mate put your dvd drive in theirs to get the game out or you need to take the case of yours and take the dvd drive apart their is no other way even taking the dvd drive apart is not easy and you could end up damaging the dvd drive getting it out.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 30, 2010 | Sony Playstation 3 (PS3) Console
Power window on driver side will not rolll up. Need a way to get it up temporarily while I am traveling.
You will have to open the door panel and remove the motor to disengage it from the window. Then you can prop the window up with a piece of wood. See my tip at http://www.fixya.com/cars/r6065762-removing_door_panels for more help.
Sep 19, 2010 | 2002 Chevrolet Silverado 1500HD
How to increase message memory in sony ericsson w700i
Hi jonothomask,
The Sony Ericsson W700i comes with 34 Mbytes of internal memory & the phone comes with a 256 Mbytes Memory Stick PRO Duo™ which will store approximately sixty four music tracks. The incoming messages will be stored in the internal memory only. So it cannot be extended even by the extternal memory card.
Please leave me comment, if you need further assistance
good luck with your fix.
have a nice day.
A VERY HELPFUL RATING IS APPRECIATED,
Thanks
Regards
Arul
Apr 07, 2010 | Sony Ericsson W700i Cellular Phone
I actually have an HP Pavillion zd8000 where I need to install a new DVD "D" Drive. I have removed all of the screws, including the ones under the battery, by the Hard Drive, the back base of the monitor...
Generally, the optical drive can be removed without taking the casing apart, just one screw holds it in under the laptop. If yours is one of those that does need to come apart, you will need to make sure that the two screwsat the rear of the laptop are undone. When you take the bexel off where the power button is, there will be two more screws holding the hinge in, they need to come out too. Then you need to remove the LCD screen before the rest of the case will come apart.
Nov 22, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion zd8000
double check for screws. there is a screw or two that your missing. normally the unit will come apart when all screws are removed. also make sure that you are not standing on carpet. when working inside of the computer.
Nov 18, 2009 | HP Pavilion zd8000 Notebook
Ribbon data cables
they are all the same, the only different one is for a floppy drive and a Sata drive
May 01, 2009 | Televison & Video
The connector of my seagate free agent 160gb is broken, can i bypass the connection with an other adaptor in the internal hard drive
Solution No1:
You'll need to take it apart desolder existing cable and solder a new one (standart you can get in any sho).
Note: If you'll mix up wires than you can damage your motherboard or hard drive itself.
Solution No2:
Take it apart, remove hard drive, buy a new 2.5" SATA Caddy and fit you hard drive to it.
Mar 11, 2009 | Seagate FreeAgent Go 120GB External USB...
My Book Essential
it is not recomeded to take it apart to get to the hard drive.
does it not work???
if you still need it apart. try lifting the rubber feet from it.
also this maybe a snap together unit with small amounts of glue at the corners. you may need to wedge something in the groove.
good luck. i dont have one in front of me so i can't see the unit.
Jun 28, 2008 | Western Digital My Book Essential Edition...
Computers & Internet Logo
151 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
