Question about Palm Treo 755p Smartphone
Treo 755p will not boot up
After sending a text message, I got an error message stating I was low on memory and "some data may not be saved." I then viewed my recent call log, and about 60% of the characters were garbled or *(#$&(*&@`/ etc.
I then removed the battery, and put it back in. My phone then would alternate between the "ACCESS POWERED" and "palm" screens during start up. I removed the battery for about an hour, then replaced it. I allowed the phone to manually drain the battery by leaving it "on." I put the battery back in, but to no avail. What gives?
I DON'T want to perform a hard reset.
Thanks!
  • 2 more comments
  • one time Jan 06, 2008
    my treo 755 is always on the screen "access powered" and is stuck there uless I remove the battery. please help
  • Anonymous Jan 09, 2009
    I have exaclty the same problem.  The alternates between the Access Power screen and the Palm screen.  Did you ever get a response that was helpful.
    Bob
  • Anonymous Jan 10, 2009
    my phone wont powere up
  • grace1055 Jan 10, 2009
    I have a very similar problem. Only, my 755p is frozen on the "Access Powered" screen whenever the power is on or the battery installed. Spent 2 hours at Alltell yesterday, to NO avail. They say "it's a bad phone" and they will mail me a replacement in a few days, and they gave me a "cute" little LG phone to use in the interim. (how nice!) This is the second time for me...and this is really two times too many. Any suggestions or quick fixes? Help>
My phone keep on booting up and shutdown than repeat the same thign again. What should I do?
Posted on Mar 26, 2008
U need a memmory card, then everything will be okay, the memory card is da key to the fone
Posted on Dec 20, 2007
Memory low error. i can't receive or send text messages. when i showed it to a friend there are no virus it seems that my phone memory has a lot of saved datas
yes, it is the reason. Free some memory by deleting the unnecessary or less necessary item to get rid form this issue.
Your can download a software Called MEMORY UP from this link. It will help you to free some memory and will speed up your phone. But keep the 1st phase of my solution in your mind. Its mandatory.
download the software from here,
http://www.nokiasymbianthemes.com/free-mobile-applications/memory-up-mobile-ram-booster-nokia-free-download-2
best of luck!
Feb 19, 2012 | Nokia N73 Cellular Phone
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Unlocked Treo 650 wont send text messages
I have the same problem using an unlocked Treo 650 on O2(UK).
One thing you need to do is make sure that the Message Centre Number is set correctly for the SIM network you are using. Get the MCN from the internet, then on the Treo Messaging > Menu > Options > Preferences > Network > Manual > Edit to check/set the MCN.
Oct 01, 2009 | Palm Treo 650 Smartphone
How can i do an upload from the data saved in my software without including the text messages. I think there might be something in the text messages caausing a virus on my phone. The softeare has several...
Backup the entire phone, it will create a directory on the computer, then you can delete the message file and restore your phone. You can also change the settings to not backup your messages if you use the Palm desktop, this is not an option using the Outlook conduit however as your messages sync to Outlook.
Oct 01, 2009 | Palm Treo 755p Smartphone
I recieve text messages fine but cannot send out. I type in and hit send but they do not go anywhere but do not get error message. Also I have a few blank text messages that won't delete
Friend, there is something wrong in your network.contact your network provider to solve the line problem. If the message cannot be deleted then there is something happened in your memory due to line failure thats why it cannot delete. try to free up your memory.
Jun 18, 2009 | Palm Treo 750 Smartphone
Treo 755p-error text and phone not working
Sounds like a bad phone. Send it back to sprint.
Nov 24, 2008 | Palm Treo 755p Smartphone
When i try to open text messages my phone turns off
i found this answer and it worked perfectly except for the error code but the solution was spot on!
Oct 25, 2008 | Palm Treo 755p Smartphone
Treo 755 with epocrates
I found that when I moved epocrates off of the storage card and into main memory, it didn't have any boot problems any more...
Sep 09, 2008 | Palm Treo 755p Smartphone
Palm 755P Freezes
Well, thank God I had done a recent Hot sync! I found out how to do a hard reset by holding down the power button while reinserting the battery then letting the button go and the system will ask if you want to erase all data? I put yes! Then it erases all my data and restarts the phone. I had to plug the phone in to be recharged because the looping ultimately drains the battery. Then, I plugged in the Hot sync cable and pushed the button to start the sync and ta da! back to its working state! Yippee! Do it! It's easy! Just make sure to hot sync often so your info stays current!
Aug 26, 2008 | Palm Treo 755p Smartphone
"Memory Low, Delete Some Data"
You might want to try a "Hard-Reset" To do this you turn of your phone, press and hold "Answer Call(Green)"+"3"+"*" and then turn it on. This should reset your phone completely and clear the memory. CAUTION, back up all your vital data before you do this, it clears EVERYTHING.
Dec 27, 2006 | Nokia 6682 Handheld
Palm Treo 755p Smartphone Logo
255 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
