Question about Dell 924 All-in-One InkJet Printer
I inserted my new series 6 810 ink into my printer and it is not printing.just blank pages.on screen it looks like its printing however it is not
Canon MP970 prints blank pages. How can I FIX that problem?
Some times when you get a new cart. a fine film can be blocking the
exit hole,check that this is clear by shaking the cart. up and down
over a large piece of paper ,if you do not get any ink out ,take a small
pin and gently insert it into the exit hole and move it around in a circle,
don't go to deep,then try shaking it again..? Another idea is to replace
all the carts.(colour ones also) as some printers wont work unless you
do this, after changing carts. disconect your printer from mains supply
and leave for about 15 minuets to reset..Hope this works for you
good luck. T.C.
Mar 31, 2013 | Canon PIXMA MP970 InkJet Printer
The printer sounds like it is printing but the page comes out blank.
Problem Blank Pages; Blank Print Out Solution
Symptom
When printing from the S or Pro Series printers, you may encounter blank pages being printed.
Solution
To rectify this issue, please follow the troubleshooting steps below:
Action Image 1
While on the main screen of the printer, open the cover.
  • If the printhead stays to the left, go to Step 2.
  • If the printhead comes to the center, do not continue troubleshooting because the printhead is faulty.
ss_mainscreen.jpg 2
Place the printer into "Replace Printhead" mode using the Maintenance menu. To access this mode, follow the steps below:
  • Touch Screen Printers:
    • Tap on the Ink Levels icon.
    • Tap on More Options.
    • Select Replace Printhead.
  • LCD Screen Printers:
    • Press the Setup button and use the arrow buttons.
    • Select Maintenance.
... 3
Open the covers and look into the printer on the left-hand side where the cartridges are inserted into the printhead - aWICKING PAD is located there.
  • If this PAD is BLACK (as seen in the right-hand image; click it for larger view), then the printer has successfully gotten ink into and through the printhead.
  • If the PAD is WHITE, then the printer has not been able to make the ink flow through the printhead. Go to Step4.
pad.jpg 4 Seat the printhead again. Unpower the printer and connect it again. Open the cover and reseat all four tanks. Press firmly on the rear of each tank and make sure all four snap in tight. ... 5
Insert plain paper and run Deep Clean.
    • Select Deep Clean Printhead.
    • Press the Setup button.
If you cannot get all four inks to lay clean, identify which one, if any of them, is failing.
  • If there is just some ink on the page - run the Deep Clean again.
  • If there is no ink at all, then the printhead is faulty.
Jul 17, 2011 | Lexmark Prospect Pro205 Wireless...
After inserting new cartridges jobs no longer print. If you go into maintenance mode on the printer it scrolls a message "align cartridges" across the display. If you press the Check mark button at that...
Are you using Dell Series 9 ink cartridges? Dell Series 9 ink cartridges have a sensor that cannot be reset. Article on refilling Dell ink cartridges
It is possible to get a Dell Series 9 ink cartridge with a bad sensor. Take it back to the place of purchase for a replacement.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
After cleaning/maintenance, pages are still blank.
If you have just bought new carts (ink) and installed them into the printer and there is blank pages. and the printer is acting like its printing (moving from left to right) and sending paper out then i would say 99.9% it is defintally the head. On the printers that have the head built in and you insert your carts (ink) into the head and you don't print but very so often this is a common problem with ink printers the head gets clogged. If you are attached to your pinter you can take it to a print shop and have them clean the head (they have to remove it from the printer)
When buy a printer if you dont print alot i always suggust to get a printer where the head is built into the cart (ink) like hp they are more expensive to repalce the ink but you get a new head every time :)
Hope this helps
Steven.
Apr 21, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Printing blank pages
Try another ink tank before you start looking for more sinister problems
Sep 01, 2009 | Dell 926 All-In-One InkJet Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
HP All-In-One HP C7280 (Ink Jet Color Printer/Scanner/FAX)
on that web page look if u have any thing which says printable version or printer friendly
try with that and check
Mar 07, 2008 | Office Equipment & Supplies
Print page comes out blank
If the cartridges are old too this may be a problem. When ink gets old it can clog the cartridges. If they are old replace them with new ones. If they are new ones did you peel the protective covering off before you inserted the cartridges? Hopes this helps
Sep 16, 2007 | HP DeskJet 952c InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
