hello i have a fridge that does not work on 110 or 12v only on propane now the frezzer compartment works o k but the fridge only maintains 12 celcius or 52 degres can any one help ????
UNPLUG AND TURN IT UPSIDE DOWN FOR A DAY OR TWO. YOU MIGHT HAVE AMONIA CRISTALS BUILT UP IN YOUR PIPES. TURN IT BACK AND SWITCH ON YOU GAS BURNER AGAIN. THIS WILL SOLVE YOUR PROBLEM. IF NOT, GET A TECHNICIAN TO CHECK IT OUT.
Defrost heater has been replaced once already. What is the best solution to protect the refrigerator...
(More)
Defrost heater has been replaced once already. What is the best solution to protect the refrigerator from power failures? Thanks, Ron
After 20 miles of very rough road we arrived at the camp ground lit the frig pilot and it will not...
(More)
After 20 miles of very rough road we arrived at the camp ground lit the frig pilot and it will not cool on LP. No electricity available. Worked perfectly before
I hav a !998 flagstaff,pop-up camper with a dometic frig.Model # RM4223, refrigerant R717,serial...
(More)
I hav a !998 flagstaff,pop-up camper with a dometic frig.Model # RM4223, refrigerant R717,serial #7330489.product#9211302-04,it's operating on 120vac ,but during the day it is pulling temp. of 50-57degr. installed in folding camper .Did get to 38 degrees over night, on a cool night plugged into 120vac in the garage.however it did not maintain temp the next day,as the day heated up .IT is not work on 12vdc n is not hooked up to 12vdc,and also could not get propane to lite. I dont think any propane was getting through. I.removed a tube,between gas inlet tube and a sort of gas control valve in back of unit,and found a small,white, filter like material inside this tube .Is That stuff suppose to be there and why?It seems to get cold during the evening, but starts to warms up as the day gets hotter.Does it cool according to the temperature outside?Do both the 120vac switch and 12vdc switch hav to be on when operating on 120vac? Does it alwys hav to be hooked up to 12vdc, if so why?Where can i get a manual and a diagram for this unit? I'd appreciate any help thank you john
