Question about Kwikset Locks & Locksmithing
My lever is loose. How do I tighten it?
My door lever is loose. How do I tighten it?
    Scholar:
  • 49 Answers
Take a flat head screwdriver and puch the spring loaded pin near the plate in and pull the lever off... use the screwdriver to pry the finish plate off, then tighten the 2 bolts you just exposed... reverse it to get lever back on...
Posted on Sep 09, 2009
The three point hitch up down lever moves as tractor is moving, handle/lever very loose.how can i tighten it up?,
I'd try to get a repair manual. MFG customer service may also be helpful, email or call.
manualslib.com may have it. There may be a locking nut that has come loose, and therefore the nut that holds it tight has also come loose. Follow the lever to where it attaches at a pivot point. Look for loose and nut to tighten.
Mar 18, 2015 | Garden
The lever style door handle: the round plate that holds it in place is loose. How do I tighten without scaring door? thx
I would like to continue to play World Class Solitare but it says unsafe to continue & may cause problems with the computer
Dec 13, 2013 | Computers & Internet
Outside sliding door handle is loose
There is 2 small nuts one on each side of the handle. You were correct in pulling the door panel as that is the way you can access them. They are difficult to see but they are there,
Dec 09, 2013 | 1994 Dodge Caravan
Loose take up lever
you can try tightening it up yourself or take it to a sewing machine repair shop and let them tighten up the take up lever and see if there is anything wrong with the lever and why it's loose.
Sep 09, 2013 | Sewing Machines
Gear shift loose. How can I tighten so that this will stop coming loose? I tighten & tighten until I break the bolt.. Any advice?
You could buy a new gear lever, if the shaft is in good condition, or you could widen the gap in the gear lever by cutting it with a hacksaw untill you have removed aprox 5mm thus allowing you to clamp up the lever, tighter on the shaft
Apr 14, 2011 | 1973 Honda CB 350 F0
I have a front door Kwikset "lever opening" front door key/deadbolt lock system which has come very loose, almost falling off. How do I tighten it up\?
on the inside of the door look on the bottom of the lock cover. There should be a hole with a screw or allen head screw. Remove the screw and you can access the the rest of the lock.
Feb 25, 2011 | Kwikset Professional Door Lock...
My moen single lever faucet is loose, how do I tighten it?
On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
Nov 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
The door knob (lever door knob to exterior fancy door) came off.
When you first tightened the screws, the mechanism may have been loose enough to allow the actuator bar the connects the inside knob to the outside lever to work loose. When you tightened it you may have jambed that tight so things didn't work. When you disassembled everything, you may have lost that part. The springs are usually integrated into the catch part and are not removeable. Sometimes it helps to take everything completely off the door including the catch that goes in the edge of the door. Then reassemble it on a table to see what works and what doesn't. If that doesn't help, take all the pieces into Lowes at the key desk and they will be glad to help you.
Jun 18, 2009 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Kenmore side by side refrigerator
If you are asking about the dispenser lever, There is a good chance it is already broke. You will need to remove the front cover. On most models, you will need a standard flat blade screwdriver and then locate the indentations on the underside of the cover trim. It takes a little force to pop the cover trim away from the door, but it will come loose. Once you have removed the cover, the dispesnser levers should be visible.
I hope this will help you to at least determine weather you can just tighten it or need to replace the lever. Please let me know if I have helped you. I can also look up the correct part and get it shipped to you.
Hope I helped
Vic
May 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Locks & Locksmithing Logo
1,136 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
