Question about XFX GeForce 6200 Graphic Card
Machine hang I play c&c 3 and then after about 5 min it hangs my machine completely.
  • jalfredom56 Sep 14, 2008
    I have the same problem with mine, i´ve tried the original drivers, the 93.71, 175, i bought an external fan that lowers the temp to 38, and does the same, i have a Pentium 4, 1.5 GB RAM, AsRock 775i65g,
  • 151 Answers
Have your tried reinstalling the drivers?
Mostly, hangs occur when the video card gets hot. Make sure it is properly ventilated, try and clean some dust up a little too as it impedes the air flow. Try cooling the system if you have a room air conditioner or just open up the case while playing and see if it hangs again...
Posted on Dec 09, 2007
Sharp washing machine won't unlock door
I was going to suggest switching t off for a while, allowing the thermal lock to release.
Mar 22, 2014 | Washing Machines
The wash cycle is taking a lot longer to do, for example the 30 min wash is taking 1 hour and sometimes longer, the motor seems fine, could it have something to do with the pump
When the cycle hangs it means that because of a fault the conditions to advance are not met.
If the washer hangs at start (filling), then there is either a problem with water pressure, blocked inlet, or water flowing back from drain hose because of incorrect hose settings (called siphoning).
If machine hangs mid cycle, then it is often a temperature related problem. Check thermostat and element or check hot inlet and thermostat if dual inlet. Testing requires disassembling and use of the multimeter.
If machine hangs mid cycle or end of the cycle (before spin), then it can be drain system. Check drain hose, drain filter attached to pump and check the pressure switch.
Most machines have a service sheet hidden inside the control panel assembly. The tech sheets shows how to run a diagnostic cycle that will tell where the problem is.
Most common faults resulting in long cycle are heat-related and drain problems.
Jul 17, 2011 | Samsung Washing Machines
My Toshiba laptop hangs in 2 -3 mins of starting
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
Apr 12, 2010 | Toshiba Satellite A135-S2276 Notebook
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Ipod hang gogear display
my ipod get hanged while playing song how can i solve this problem
Jul 20, 2009 | Philips GOGEAR SA6045 MP3 Player
Xvid playback hangs on dane elec so smart unit
Did you try updating the firmware? has the latest firmware. I have a SO Smart, no problems at all playing XVID files. I have it upgraded to the latest firmware 1.0.4.
Sep 26, 2008 | Dane Elec DANE-ELEC DA-M4-04-ML2 Meizu 4G...
Check your settings in your answering machine menu. 1) is it on? 2) number of rings? 3) is it set to take messages or answer only? If the machine is ringing and never answers look for a problem under items 1 and 2. If it answers, plays your greeting then hangs up on the caller, look at number 3. If all those settings are correct, power it down, repower it back up, wait a few minutes to call it.
Jan 29, 2008 | Panasonic KX-TG5632 Phone
Answering machine...
There is a problem with the machine take it back or send it in if it is in warranty. Or take it to a service center.
Aug 07, 2007 | Vtech i5871 Cordless Phone
Answering machine hangs up during greeting
this problem is cause by excessive loop current from telco. the answer to this is to put a 600 ohm resistor in series with either tip or ring to the cable which feeds the answering machine. excessive loop current related issues can be the toughest problems to troubleshoot
Oct 14, 2006 | Vtech i5871 Cordless Phone
XFX GeForce 6200 Graphic Card Logo
48 people viewed this question
Top XFX Computers & Internet Experts
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
