Question about Bose & Wave& Music System
CD's stuck - how do I remove cover from wave multi-disc changer
I have the 5 disc multi changer for the acoustic wave system. There were 2 CD's already in it when I turned it on recently. I put a CD in the #3 slot and sounded like it tried to load up, but didn't, and now nothing works. I can see the CD's in the #1 and #2 slot, but not the one in the #3 slot. When I power up the system the #3 slot is green and the #1 & 2 slots are yellow. I have tried the reset by powering off and on, turning it upside down and powering up but that doesn't work. I have tried everything I could think of to eject them. If I push the eject buttons on the #1 and 2 slots, they blink but nothing happens. I can hear that there is something going on (the mechanisms are trying to do move?) when I push the eject buttons. I thought if I could remove the cover I could at least retrieve the CD's. I think I have removed all of the screws from the cover (8 - 1/2" and 1 tiny one) but am unable to figure out how to get it off. There is a hole aprx. in the middle of the bottom and I am unable to see clearly but it does not appear to be a screw and I'm not sure if that is what is holding it down. Any help removing the cover, or other suggestions that do not involve removing the cover but might cause the discs to eject would be appreciated.
3 Suggested Answers
SOURCE: i have a Bose acoustic
I called Bose service. Jason said to unplug for 1minute then plug back in. If the changer does not reboot and operate properly....you call Bose service. They will exchange your cd changer for a new one.
$75 plus tax and return your cd's to you. They will give instructions for the exchange when you call.
Posted on Oct 31, 2008
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
My 3 disc change not working properly. cd are d2 and d3 and will not ejeck
Loosen 4 screws on bottom. You may want to take the two front ones out. They are phillips head. Drop the botom portion of the changer down about an inch or so. You will see all the disc that are stuck. Take a pair of micro plyers and simply grab the edge of the disc and gently pull and it will come out very easily Be sure and grab the very edge of the disk so as not to damage it. It took me all of 5 minutes to remove the disc in a 3 disc changer. What caused it to become stuck in first place is another question. You shoud have a green light beside each slot that has a disc in it.
Sep 24, 2016 | Bose Wave music system Multi-CD Changer...
How can I eject my stuck cd multi-cd changer
Had the same problem with mine.....turn it over in your lap and give it a slap..not to hard. that should work. If not, remove the cover and flip the release button located in back. good luck!!
Jul 27, 2014 | Bose Wave music system Multi-CD Changer...
Wave Music system Multi-CD Changer
The unit has a power supply problem, no user servicable parts inside. Bose uses a thermal fuse built into the power transformer. Take unit apart and check for connection issues first, then look for a possible fuse, if none exist chances are it is in the power transformer, contact Bose for service.
Sep 02, 2012 | Bose Wave music system Multi-CD Changer...
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
Can the new 5 cd changer work with the older Bose
It will work as a manually-operated AUX input, but since there was no remote for the original system so that function won't be available.
Nov 29, 2009 | Bose Wave Music System CD Shelf System
I have a Bose acoustic wave muti-disc changer.i have 5 disk in changer,i cannot eject any disk,& it looks like its hung up on # 5.non of the disk will play. Thank You-
Aug 22, 2008 | Bose Acoustic Wave (32022) 5-Disc CD...
Bose & Wave& Music System Logo
416 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
