Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Cannot Stop Closed Captioning Feature
I had family over the house this weekend and someone turned on the closed captioning feature and I cannot get it to turn off.
I went through the process of finding the ''cc'' option and selected 'off', however, the cc continues o be displayed on my television.
Please help.
  • 80 Answers
You might want to make sure it's the tv's close captioning your watching and not your cable or sattelite box's closed captioning, either way you might have to get into the menu of your box, not the tv to turn it off.
Posted on Sep 07, 2009
How do i delete closed captioning?
The button marked CCD "close caption display"
BTY if the TV programing is coming via cable box that the CCD feature needs to be turned off in the cable box under settings. If there is a cable remote the CC will usually be near to the "cable" button
26052381-dbyvlhzmxmckmsztft4cqgrd-4-0.jpg I hope that this helps?
Jan 13, 2016 | Dynex DX-L19-10A LCD TV
I can't turn on closed captioning on Hitachi with Comcast scientific atlanta explorer 2200 cable box. Any words of wisdom?
Both the set and the box used should have the closed caption feature.
If box is in line to rear audio/video jacks you will have to engage the CC from the box.
I doubt it will work if hooked that way from within the box---go to menu and in CC area in either set or box select CC1 which is the most common one used.
May 25, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Can't enable cc on my vizio
it might be because the box has this feature also and it is enabled there
Mar 26, 2012 | Televison & Video
How do you remove braille from tv
If you are talking about the words spoken on the TV program being displayed on the TV screen as text, then this feature is called CLOSED CAPTIONING.
Most remote controls have a button called CC, or CAPTION, or INFO, or DISPLAY which will allow you to disable the CLOSED CAPTIONING feature.
Otherwise you may have to select the MAIN MENU option for your set and go into the AUDIO OPTONS or FEATURES menu. If you can find the Closed Caption settings in there, then just disable them there by setting them to OFF.
If you can provide the exact brand and model number of your TV, then we can certainly provide you with more specific instructions on how to disable that feature on your particular set.
If you have a cable or satellite set top box, then also make sure that the Closed Captioning is not being generated by that device instead of by your TV. Make sure the Closed Captioning is disabled on that set top device as well if applicable.
I hope that was helpful.
Good luck and take care.
Joe.
Dec 15, 2011 | Philips Televison & Video
I wish to use closed captioning but I can't find the function on my Panasonic TH-42PWD6 monitor. Does it have a closed captioning function, and if so how can I turn it on and off? Thanks.
Researching this monitor, it appears to be a professional monitor with plug-in modules for different inputs. It does not appear to support closed captioning natively.
However, some Set Top Boxes (STBs) do closed captioning themselves. For example, most newer DirecTV STBs have captioning capabilities on the box rather than using the montior's closed captioning feature. Perhaps your source material can open caption for you.
May 06, 2011 | Televison & Video
Does the toshiba 27a44 have closed captioning?
Hello
You have two options with closed caption feature.
Captions of Text
A caption is a printed version of a dialogue narration and/or sound effects of a programme. Text is information not related to the programme that appears on half of the TV screen when available.
To view Caption or Text
[1] Select the desired programme. Closed captioned programme are usually marked in your local TV listing as "CC"
[2] Press CAPTION/TEXT repeatedly to select caption or text mode.
[3] Press 1/2 to select the caption or text channel.
[4] To turn to off the closed caption feature, press CAP/TEXT repeatedly until captions or text no longer display 0n-screen.
Ok.
Nov 15, 2010 | Toshiba 27A44 27" TV
WE HAVE A BLACK BOX IN THE MIDDLE OF OUR TV AND CAN'T GET IT OFF WITH THE REMOTE
Black boxes in the middle of the screen are text boxes. Text is a part of the closed captioning feature either on your television or your cable/set top box. You would press the closed captioning button on the remote repeatedly until it displays cc off or something similar. Captioning might also be active on your cable box/set top box. There is normally a hidden menu on the cable box and that is where closed captioning is. You have to turn the cable box off. Yes I did say turn the cable box off. Then press the menu button on it and then the hidden menu will pop up. Then navigate to closed captioning and choose disable.
Nov 09, 2010 | JVC Televison & Video
How do I get closed captioning on my 625 dish dvr.
Guest,
The 625 receiver does not have a setting to control closed caption. This is a setting from your TV itself. I would look at your TV manual to see how you can turn the feature on. I hope this helps.
Ray Calo
DISH Network
May 19, 2010 | DISH Network DVR-625 DTV Receiver /...
Black Box On Screen
Salutations Cranberries,
The annoying black box is usually a feature of the closed captioning called "Text" You should be able to go in to onscreen menu and select caption options. Unless you need to have the closed captioning on for medical reasons, it maybe best just to turn off all captioning options.
Hope this helps.
Jon
Go Ahead. Use Us.
May 27, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
