Question about Compaq Presario 2100T Notebook
Stat up pressed reset button
Compaq presario 2100 screen blank not responding pressed reset comes on blank no respond
  • bo hunter Dec 16, 2007
    compaq presario 2100 notebook...While on the internet the screen blinked off twice and came back on and within 3-4 minutes it just went totally blank..I turn the laptop off waited a couple of minutes ,turn on machine seems to boot but still no screen...?Any help would be appreciated..I think it's a 2002 model..Thanks, Chris
    my email is hunterproperties @excite.com
  • Anonymous Mar 15, 2008
    I just bought a new screen for my presario 2100, i plugged the screen in and turned the computer on but nothing is showing up on the screen.
  • 106 Answers
Try CTRL ALT DEL
Posted on Dec 09, 2007
Compaq presario v2000 won't load os. keyboard not responding
can you clearly explain the problem.keyboard not responding means always or when you want to press enter to load os
Sep 15, 2013 | HP Compaq Presario V2000 Notebook
I have compaq presario 2100 i was using for 7 months now the screen is black can give me any solution
Try booting in safe mode by pressing the f8 button after the bios post choose safe mode and if you see the display just go to device manager through right click on the my computer and manage and display driver right click and uninstall and restart the comp and should be fine\
Thanks
Dec 05, 2010 | Compaq Presario 2100 Series: 1170B01-90...
Compaq presario 2100 shuts down but power light stays on and drains battery thanks
Try to press and hold the power button for about 5-10 seconds. If it does not respond, pull the battery out, and put it back in.
Apr 20, 2010 | Compaq Computers & Internet
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Not responding for power button when i press
Hold it down for 15 seconds,if it goes totally off,change your power setting in the control  panel
Oct 10, 2009 | HP Compaq Presario R4000 Notebook
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Feb 06, 2009 | Compaq Computers & Internet
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 2100T Notebook Logo
154 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
