Question about GE Refrigerators
GE TBF19ZB won't cool. Motor is running, But, refrigerator and freezer are not getting cold enough. Refrigerator and freezer are set at middle settings
    Problem Solver:
  • 16 Answers
Dirty condenser coils or condenser fan not working most common problems,condenser is at bottom of refrig. next to compressor.
Posted on Sep 08, 2009
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
Temperature playing up going up not down
Refrigerator Not Cooling Enough - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
If the refrigerator is running, but not cooling at all or is not cold enough, several ... To view a short video on adjusting the temperature on set point models: Play ...
How To Fix A Refrigerator and Freezer That's Too Warm ...
www.partselect.com/Repair/Refrigerator/Refrigerator-Freezer-Too-Warm/
If your fridge and freezer is too warm, don't give up - we can help. ... The cold control is a temperature controlled switch that supplies power to the compressor ...
Nov 21, 2015 | Refrigerators
I have a GE side by side refrigerator bought in 2003. The freezer is not cooling enough and the ice creams have melted. The fridge is not cooling much but it is cooling enough to maintain the stuff in it....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi my GE side by side fridge is not getting cold enough
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Inside of frezzer is getting a frost build up and fridge is not getting cold enough.
heatman101 ..
Nov 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator does not keep cold. Motor runs and freezer does freeze.
heatman101
Oct 19, 2010 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator and freezer not cold enough,evaporator coils look frozen
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Sep 26, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Fridge side is not cold enough
heatman101
Sep 25, 2010 | GE GSS25SGMBS Side by Side Refrigerator
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
