Question about ASUS Computers & Internet
BIOS jumper settings of a ASUS P2B-VT motherboard
I'm looking for a diagram of a ASUS P2B-VT motherboard showing the location of the BIOS jumpers,and all the settings.
    Genius:
  • 1,027 Answers
I found a source with a similar model. the exact one not available as the board was a custom OEM version. Try this link;
http://dlcdnas.asus.com/pub/ASUS/mb/slot1/440bx/p2b/p2b%28pcb1.02%29.pdf
Posted on Sep 07, 2009
Need to change mouse settings on bios but i forgot my password
use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Jan 24, 2011 | ASUS M51Ta-X1 NoteBook
Hi, I messed up my BIOS by trying to update it... I got an asus p4b533 and cant find how to do a CMOS reset. I read about shortening two bumps because this board obviously has no jumpers to reset CMOS....
Make sure to turn the PC off before opening the cabinet and resetting the jumper
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope this helps
Jan 16, 2011 | ASUS P4B533-VM Motherboard
I open the intrusion selector by pulling out jumper then turn on computer then bios says system tampered i turn it off then put jumper again and set bios to default but my computer not responding to...
There is a jumper that resets the bios clock password etc...etc
You need to locate it 3 pin set 1 jumper and look for <norm/reset> in small white print.
Self explanitory
Aug 23, 2010 | ASUS TUV4X (TUV4X/533/PA/6P-UAY)...
Chassis intruded... fatal error.. system halt..
If your case is not setup for chassis intrusion, the motherboard has dropped a jumper.
The location is by the last PCI slot between the CD audio connector and the USB bus plug. (it is right next to the CLRTC jumpers)
Good luck
Jul 21, 2010 | ASUS P5KPL-AM SE Motherboard
Bios password, how do i remove it. I need to change the boot system to install windows.
Unplug the power cord from the power supply.
The fastest way to clear the bios password would be to first find the bios/cmos battery on the motherboard. See the picture below.
Next find the 3-pin bios jumper. Asus motherboards usually mark the motherboard bios pins as, CLRTC.
It will be rather close to the bios battery. Pay attention to the current position of the bios jumper. It is currently set as normal. The jumper will cover pins 1 and pin 2.
Remove the jumper and place over pins 2 and pin 3. Doing this will clear the bios and will reset all bios settings to DEFAULT. Grab a small flat- head screw driver. Gently insert the screw driver slightly under the battery edge to help you to remove the battery. Wait 30 seconds and reseat the battery. Reset the bios jumper back to pins 1 and pin 2.
Reconnect the power supply cord. You will need to enter the bios and re-configure all your settings. Use your motherboard manual to help guide you through all your bios settings. Next time include the model number of your Asus MB.
Happy holidays!
Mike
Dec 19, 2009 | ASUS Computers & Internet
What is the purpose of the diagram of jumper setting?
The jumper settings (if this is the one you are speaking about) are for clearing the BIOS (times, dates, hardware etc...). The diagram is probably showing the settings on which pins to jump when clearing.
Hope this helps.
Nov 09, 2009 | Intel D865GBF Motherboard
Need to reset Asus k7v bios
Yes, if you consult your motherboard manual this will show you the location of the cmos battery and reset jumpers. You can either move the jumpers from pins 1+2 to 2+3 and then back again after a few seconds or remove the cmos battery for a few seconds. Make sure your pc is off!
Dec 16, 2008 | ASUS VIA KX133 Chipset K7V (K7V/500/SWA)...
BIOS flashed with wrong version
Remove the CMOS battery will reset the bios ( not sure how you could have installed incorrect bios it would tell you it the wrong bios )
Jul 18, 2008 | ASUS Intel 440BX Chipset P2B Motherboard
Flashed the bios with wrong version PC is unusable
Hi, I dont like your chances a lot. Next to the cmos battery you will find a set of jumper pins [3 pins] move the jumper from where it is set onto the next pin and leave it there for at least 10 seconds then replace it back in its orriginal position. This will reset all the orriginal bios settings. If the update flash you have done doe's not allow this to reset, get onto the ASUS web site and ask for tech help, the response may be slow but this is your only option other than another mobo. Regards mistyman
Aug 27, 2007 | ASUS Intel 440BX Chipset P2B-N Motherboard
No video etc.
on the motherboard will be a JBAT1 terminal with the jumper across pins 1-2, so put jumper on pins 2-3, then back to pins 1-2. If not JBAT1, then it may be a 2 pin terminal called CLRCMOS, of which you put a jumper across the two pins for seconds then remove. Although, i can't think of a way to update the bios without seeing whats on the screen.
Mar 27, 2007 | ASUS Intel 440BX Chipset P2B Motherboard
Computers & Internet Logo
671 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
