Question about Cell Phones
Usb port doesnt recognize my Motorola i335 Boost Mobile phone
My usb port doesnt recognize my Motorola i335 Boost Mobile phone. Ive plugged it in and it said new hardware found. When I went and looked for it to transfer some of my ringtones it was gone. The port didnt recognize it.
Please my motorola i335 was a boost mobile cell phone. I will like to change it to another network.for example MTN. So that if I put an MTN sim card, it will connect. That is decode from Boost mobile.
Any phone that runs off the IDEN network will ONLY work on the iden network. It's physically impossible to use it on any other service.
Iden is such a weak signal that's only like 800mhz. There's no way ever to use it on anything other...
Technically the I335 was only designed for professional use which is why it has push to talk and 'rugged' design.
Aug 03, 2011 | Motorola Mobility I335 Cellular Phone
My boost mobile i335 motorola is not able to send text mgs. I can recieve text. And when i try to view "sent messages" the phone turns off, then on. Phone has always worked until recently.
Have you recently dropped it? If this phone is expensive and you cannot buy a new one or get it repaired, there is no way of fixing it. By the way, most of the time it is actually cheaper and easier to buy a new one rather than getting it repaired.
Jun 05, 2011 | Motorola Mobility I335 Cellular Phone
Im trying to see how can i recharge my boost mobile i335 phone on my computer
Iden phone motorola driver package. They have usb charging drivers for it.
Their tricky though to instal so unless you have the time and patients. I'd stick to wall charging.
Jan 16, 2011 | Motorola Mobility I335 Cellular Phone
When I plug into usb it doesnt recognize it
while your phone is plugged in go to start, control panel, add new hardware and go through the setup wizard.
Mar 03, 2010 | E-Machines W1800 PC Desktop
I have a motorola i335 i purchased from ebay hoping to use it with boost only to find out it has a nextel sim card ...can i still use it with boost?
Yes you can use it, but, you need a boost sim card.  Nextel phones work fine on Boost (same network) but you need a boost sim.  You can get them cheaply on ebay, often with the $5 dollar credit for under $10.00.  Otherwise go to a local phone store and get a boost starter kit.  They are made so you can start service with a boost or nextel phone.
Feb 08, 2010 | Motorola Mobility I335 Cellular Phone
Motorola i335 code
if you want to use your phone on a service like t-mobile or cingular, it wont work, you can only unlock it for iden, like boost mobile, nextel.
you can unlock it your self by going here
http://multiplexelectronics.home.att.net/software.html
Jul 15, 2009 | Motorola Mobility I335 Cellular Phone
Boost mobile i335
i dont get service at my home but my sister who also has a boost phone gets service. i have a i335 and she has a white phone she paid 29.99 for. i called boost and they told me that i have to try to see if it is the phone or sim card. how can i check to see if there is something set up wrong or if the transmitter needs to be changed?
May 24, 2009 | Motorola Mobility I335 Cellular Phone
I can't get unsupported objects such as ringtones through bluetooth.
To the best of my knowledge, this happens because Boost Mobile does not want you to be able to get ringtones from anywhere but through them. If someone sends you an MP3 file in a message, that file most certainly would be supported by your phone, because the Motorola i335 supports MP3 files. However, Boost Mobile can be greedy at times. The reason they tell you that the object is unsupported is because if they would let you download the object and allow you to save it to your phone, you would be able to use it as a ringtone like you want to. If you are given the capability to use files from the internet, friends' phones, etc. as ringtones, Boost Mobile loses money, because you get the ringtone, and Boost receives no compensation for it, making it unnecessary for you to buy anything of that nature from Boost.
May 04, 2009 | Motorola Mobility I335 Cellular Phone
Pin blocked motorola i335
if it says sim pin blocked you will need another sim card, go on ebay and get a 5.00 starter kit with IMEI for like 4.50
Jan 31, 2009 | Nextel i355
Cell Phones Logo
317 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
