Question about Garden
I have a very weak spark and I have changed the coil what could possibly be wrong
  • 96 Answers
Spark plug wire could be shorted or plug could be going bad
Posted on Sep 07, 2009
We replaced the ignition coil on our Husqvarna 128 cd trimmer because of weak spark. now no spark, any ideas as to the problem?
Is it possible you connected the coil wrong, maybe reversed the wires, just a suggestion.
Oct 19, 2016 | Husqvarna Garden
I have an 1988 Yamaha Phazer 500 coil spark is weak on one cyl could it be the coil or what?
easiest way to see if the coil is weak is by swapping the wires if possible from side to side and see if the weak spark follows.
Nov 27, 2015 | Yamaha Motorcycles
2008 Cadillac CTS returning P0303 after replacing spark plug and coil pack
Error Code: P0303
Description:
Cylinder 3 - Misfire Detected
Possible Cause:
Wiring harness, igniter and fuel injector connectors.
Ignition system. (Spark plugs gaps)
Fuel injector No. 3.
Fuel pressure.
Running out of fuel.
EVAP canister purge valve.
Evaporative emission system.
Low compression, cylinder No.3. (check valve clearance and throttle plate for excessive wear)
Engine control module (ECM).
Feb 27, 2014 | 2008 Cadillac Cts
1996 jeep grand Cherokee will turn over but not start. weak spark. fuel at fuel rail. replaced PCM 1 month ago. replaced crank shaft sensor 3 months ago....
See if your getting spark at the ign. coil first (passengers side on that year) if you are change the crank shaft sensor making sure you mount it as close to the engine as possible so it never gives you trouble again.
Aug 20, 2013 | 1996 Jeep Grand Cherokee
Weak spark at plug
Check to see haw strong the spark is coming out the dist cap. If it is weak there, possible bad cap/rotor/coil/ module. Make sure the wire from the coil to the cap is good.
Jan 01, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
I GOT NO FIRE ON THE PLUGS
The spark gets power to spark from coil packs.If the connection between coil pack to spark plug is weak or loose then it will not fire.But if the coil pack as well as the connection between coil pack to spark plugs checked ok then its faulty or dirty spark plugs.Clean the spark plugs with the carb cleaner liquid and let it completely dry.Then check.Also check the voltage between coil pack to spark plugs.If both checked out ok then the other possibility can be weak crank shaft sensor. Thanks.Helpmech.
Nov 12, 2010 | 1995 Dodge Dakota
Won't run. has spark (weak)fuel to fuel rail.
id be leaning twords a coil pack on this one, if the spark is weak change the plugs and wires first since its cheaper, then if that doesnt cure it change the coil pack.
Mar 19, 2010 | 1995 Volkswagen Jetta
Weak Spark to coil
My dad had a 93 GC and he had to replace somekind of crankshaft sensor then it was fine ever since. I guess those inline 6's are known for that.
May 26, 2009 | 1995 Jeep Grand Cherokee
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
