Question about Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord
Sawzall model 6507 goes dead when horizontal. roudy45176 suggested: One of the pins for the quik lok was loose and pushing it down (way in) did not tighten it or correct the problem.
    Sergeant:
  • 384 Answers
Loose wire connection in electrical cable.
Posted on Sep 08, 2009
Saw blade jammed - cannot remove
Unplug from power. Spray blade locking mechanism with wd40 or similar lube. 1. If you have a quik release, work the release with a pair of channel locks while wriggling the blade. If not removed, you can remove the footplate from the saw and drive the pin out that holds the quik release in place, paying attention to how the parts reassemble. 2. If you have a set screw retainer, totally remove the retainer.
Sep 08, 2012 | Milwaukee Tool 10 Amp Sawzall Plus with...
Milwaukee sawzall blade
Cut or snap the blade off at the end so you can get the holder apart. I have had to do this before. Usually you can just use a set of pliers and work the blade back and forth until it snaps off but I just use an air powered cut-off tool and cut them.
Aug 05, 2012 | Milwaukee tools Milwaukee 6509-22...
Milwakkee cordless lithium sawzall clicks but blade wont move
you have a gear problem, if this is a newer sawzall I would take it back for warranty repair. If you need a breakdown you can go to milwaukeetool.com and download one. They have a good warranty
Jan 27, 2012 | Milwaukee Tool Milwaukee 10 Amp...
My dog chewed up cord. How do I repalce Milwaukee Model 6507 Sawzall
this should be a twist lock cord and all you need to do it twist the connector at the handle area and pull the cord off and buy a replacement, make sure whether it it grounded (3 wire) or double insulated (2 wire), you can go to Milwaukeetools.com and with your serial number look at a schematic for this tool and they also have a dealer locator to ensure that you get the proper one. Let me know if you need more assistance.
Sep 19, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
Can't get the quick-lok cord to release from sawzall
On my current sawzall I dont't have the quick lok cord, but my last one did and so does my milwakee hammer drill. To remove cord push in on cord firmly where it goes into base of saw. Turn counterclockwise and rotate about 90 degrees. Pull gently on cord base and move slightly from side to side. This should release cord. Reinstall carefully by reversing . Hope this helps you.Thanks.
Nov 16, 2010 | Milwaukee Tool 10 Amp Sawzall Plus with...
Motor on my sawzall 6572 runs but blade does not move. Blade locked in tight. No reciprocating motion.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Jul 27, 2010 | Milwaukee Tool Milwaukee 10 Amp...
Missing the blade holder thingy for sawzall cat # 6527. Thanks, Mike
Mike, is this the quik lok blade assembly and if so the part number is 14-46-1011 and if not you would need to go to Milwaukeetool.com and type in your model number but you would also need to have the serial number handy for the different versions and parts for these tools. If you want to forward it to me I will come up with a part number for you.
Oct 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Sawzall goes dead when horizontal top right
could be a break in the cord or a loose terminal at the brush holder. If you are mechanically inclined get back with me and I will instruct how to find. You will need the exact model number. If this is a quick lock cord as listed unplug and look at the terminals to make sure one not pushed away from tool and condition of the plug in handles. Let me know
Sep 06, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Cannot get blade to release from Sawzall Quik-Loc.
Will the collar on the Quik Lok Turn and if so how much? What you can do is spray some WD-40 on the mechanism to free up the collar, sometimes it gets gummed up from cutting. It should open and close with a snap, hope this helps
Nov 29, 2008 | Milwaukee Tool Milwaukee 10 Amp...
Milwaukee Tool 10 Amp Sawzall Plus with Quick - Lok Cord Logo
235 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Dave
Level 1 Expert
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
