Question about Garden
I have a craftsman weedeater 32cc that will start but dies out when I try to give it gas.
SOURCE: have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
Posted on May 10, 2009
  • 143 Answers
SOURCE: weedeater will not run with choke off
Check your carburettor mounting screws,they might be loose and it would mean the engine is
getting to much air and it would leak gas. Stephen
Posted on Sep 06, 2009
  • 11 Answers
SOURCE: I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
Posted on May 05, 2010
  • 100 Answers
SOURCE: 32cc Craftsman weedwacker dies at idle
could be blocked muffler
Posted on Aug 14, 2010
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
I have a 32cc craftsman weedeater. I put new fuel lines on it because they were falling apart, and I don't have the fuel filter on it right now, will that make a difference? It will start, but as soon as I...
Hi, yes the filter is in place to protect the delicate workings inside of the carburetor. Something my be blocked partially letting some fuel pass but when the throttle is turned up the supply cannot match the demand and it fails. Try to give the carb a good cleaning. If the the fuel lines are such that they need replacing then the carb itself could probably use some attention. hope this helps.bv
Nov 16, 2010 | Garden
My Craftsman 32CC weed trimmer wont start. I believe no gas is getting into the carb, becuase if I pour a small amount of gas directly into the carb it starts, but then quickly dies.
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
I have a 32cc Craftman Brush wacker trimmer and the fuel line fell apart I need to know how to install the new ones.
This problem seems to be the biggest and most popular one by far in these forums and has been answered several times. Try and post your problem using the search feature on this site. Don't use too many words. Craftsman Weedeater Fuel Lines should be sufficient. If you can't get it, then post back here again please.
Aug 07, 2010 | Craftsman 25cc Gas Line Trimmer
Weedeater will not run with choke off
Sep 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
May 04, 2009 | Craftsman Garden
Craftsman weedeater wont start
The problem that I had with my craftsman was that I found that there was a tube in the fuel tank that goes to the carb, & at the other end - inside the tank, there was a small screen with maybe a weight on it (to keep it in the gas no matter what position the weedeater is in). Mine was plugged up and i went to the saw shop and got a generic hose & end with the screen deal & changed them out. Solved my problem. Rick
Mar 24, 2009 | Poulan Genuine Weedeater Part # 36006-128
Garden Logo
205 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
