I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the compressor. The original G.E. motor had 4 wires, one of which was not hooked up. The replacement motor is an A.O. Smith model OAM10088 with 3 leads. Smith sent me a new 2-pole capacitor for the new motor. How do I wire it correctly?
  • HANK MCNEIL May 11, 2010
    wire colors???
  • 334 Answers
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Posted on Sep 07, 2009
What type and size condensor fan goes in a 2 ton split system?
depends on the manufacturer. go to manufacturer internet site with model and serial numbers for parts info. if you are talking about a system other than rheem,trane,lennox. it is usually in the 1050 rpm, 220 volt,1/3 hp and you could use a rescue motor to replace it with. reversible motor.
Oct 11, 2015 | Heating & Cooling
Trane xe1200 compressor fan motor only runs for about five minutes
Than it's not wired correctly. Did you splice the motor wires? Black on left, common to cap which should be the right from contactor and fan which I think, without looking, is brown. purple common...
Jan 17, 2018 | Heating & Cooling
Heat pump Trane XE1000 needs new condensor motor and run capacitor
you could replace it yourself remove old mtr & cap. info. you need should be on body of each if not check unit call supply stores or local company for parts
Mar 22, 2012 | Heating & Cooling
I have a trane xe1200 heat pump and washed out my condenser coil.I wired it back in but I think my fan is running backwards,I feel hot air coming out of the louvers rather than from the top,is this...
Hi, you say you wired it back in? Yes it is possible for the fan to run backward if the motor is a reversible motor. And yes, if its not running in the right direction, it will not keep the head pressure down like it should. On a reversible motor, they have 4- wires at the rear normally, that you interchange to reverse it. I don't know what wires you disconnected, but unless this is a 3 phase motor which I no its not, you would have had to change those 4- reversing wires to make it run either ccw or cw. It will tell you on the motor how to do this and the rotation. The blade on the fan is positioned to scoop up the air when turning, so you can look at it and tell the direction it goes. Air is pulled through the coil and out the top, or your head pressure we stay high and cause damage to the compressor in the long run, or shut it off on high head switch. I hope this has helped you. Residential units are single phase motors that can only be reversed if made to be, and can be changed by switching those 4-wires around.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 17, 2010 | Heating & Cooling
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Aug 19, 2009 | Heating & Cooling
Condensor fan runs after compressor shuts off
If new motor is 4 wire verses 3 wire use seperate capacitor between brown wires and don't use terminal on 3 pole cap. If this motor has a white strip on one brown wire you can wire it the old way using only 1 brown wire and tape off the other. Can't remeber this morning which brow wire to use . I need to leave. Goole replacemotor with 2 brown wires for more info or call where you bought it. Sorry got to run.
Jul 01, 2009 | Weather King 12AJA4801AH Air Conditioner
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Want to know capacitor specs. for 3 ton Janitrol Condensor Unit Fan motor capacitor and Compressor capacitor
The capaitors should be clearly marked on the original capacitors. You will find a voltage rating and an MFD rating printed on them. The rule is you can go 10% over but never under on the ratings.
Jul 11, 2008 | Goodman Heating & Cooling
Condensor motor turn very slowly.
I do believe you will find the Mother Board is the cause of your problem. I also believe your original motor was ok. The motor runs on DC voltage. There are 3 wires to the motor. The red wire is a sensor wire. The other 2 wires should provide 12 to 13 or so volts DC to the motor. If it is not the mother board is bad.
I hope I helped. supertechks
Mar 05, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Heating & Cooling Logo
2,146 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
