Question about D-Link DI-704P Router
DI-Link model DI-704
I've reset my router several times before, but this time the M1 and M2 lights wont display. Is my router belly up.....
  • cindy14 Feb 10, 2008
    I've tried resetting my router with the same model. Some say it's belly up. But the router is 4 months old. I don't have any idea. My problem started when i had my server reformat. The internet interruption started. Would you believe my internet shop is closed for 2 Months. Losing a lot of money.
  • Anonymous Apr 11, 2009
    same me to
I have the same problem... my connection after an hour will slow down but after i turn off and on the router again, my connection will back to normal again... Can u please help... thanks.
Posted on Mar 29, 2008
Password1752809
If you forgot your password and/or want to reset the router back to the default settings:
Step 1 Power the unit off by unplugging its power adapter.
Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case). The default IP address is 192.168.0.1.
BEST OF LUCK
Dec 15, 2013 | D-Link DI-704P Router
Hi I try every solutions existing on the internet but I can't connect to 192.168.0.1 ip to configure my di-704 thanks
Here is a Webconfig for your router/gateway http://support.dlink.com/emulators/di704/IndexLogon.htm
Also the default login is admin with no password but sometimes may use the word password for the password with the login of admin
more info can be found here http://www.dslreports.com/faq/9098
And every thing else you need to know about this gateway is here http://www.techrepublic.com/article/mastering-the-d-link-di-704-cabledsl-gateway/1032657
Mar 12, 2011 | Computers & Internet
Im forget my password i would like to reset my DI-614+ but when i press the button reset it dnt make noting
You may held the reset button too long, try again:
How to reset D-Link router to the Factory Default Settings
In general, to reset the D-Link to the Factory Default Settings, please follow these steps:
1. Turn off the router
2. Locate the Reset button on the back of the router.
3. Use a paper clip to press the Reset button and power on.
4. Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
5. After you have completed the above steps, the router will be reset to the factory default settings
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Dec 31, 2010 | D-Link AirPlus DI-614+ Wireless Router
I cant secure my dlink. Every time iuse the wizard and i am asked to put in admin and leave password blank, it wont accept. I'm not sure if I have put a paasword in before, but i cant progress past this...
this should get you into the setup screen thru your internet browser! thats if a password has not been set if it has you must reset and reconfigure the router!
user is: user
password is:password
Aug 29, 2009 | D-Link AirPlusG DI-524UP Wireless Router
Can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | D-Link AirPlus DI-614+ Wireless Router
D-Link Vpn Router model DI-804HV
Can you tell me the setup with your router? It should be Internet->Modem->Router->Computer If that's setup properly (the wires in the right spots) then go to the gateway IP of the router...it might be something like "192.168.0.100 "so you put that in your internet browser. The default user is "admin" with no password. Make sure to run the "Wizard" while on that page and after that go to the "Status" page and check to see if the WAN connection is connected properly.
Aug 28, 2007 | D-Link DI-804HV - 4-Port Broadband VPN...
Problem with a 704 p router
to do a hard reset, hold for about 5 seconds (don?t hold too long) and then release. (Or, release when M1 and M2 flash at the same time.) The M1 amber light flashing means that the system is active. Go to your routers settings by typing 192.168.0.1 and make sure that enable DHCP is showing and that the network adapter cards in your pc's are set to obtain an ip address automatically, to do this start>control panel>network connections, then on your network adapter ensure it says enabled, if so right click on it and select properties, go to TCP/IP line and click properties and make sure obtain ip address automatically is ticked, ok it and restart pc and see if you get a connection.
Jun 25, 2007 | D-Link DI-704P Router
Factory setting
Step 1 Power the unit off by unplugging its power adapter. Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure. Step 3 Power the device back on by plugging it in. Continue to hold the reset button. Step 4 Watch the lights on the front of the router. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button. The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, unplug the power on the router and plug it back in. If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
Feb 16, 2006 | D-Link DI-704P Router
Factory settings
Feb 16, 2006 | D-Link DI-804HV - 4-Port Broadband VPN...
Factory settings
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
D-Link DI-704P Router Logo
346 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
