Question about Sylvania 6615LE LCD HDTV
Can the cablevision remote learn to control a receiver volume
I would like to be able to control my yamaha receiver VOLUME with my cablevision remote....possible????
  • Anonymous_NJ Jul 17, 2013
    I am in the same boat, i have cable vision/optimum remote and want to control yamaha receiver volume....
3 Suggested Answers
romsky79
  • 822 Answers
SOURCE: same as above
please check the battery of your remote, that the main cause your problem.
Posted on Aug 09, 2009
John-INSG
  • 312 Answers
SOURCE: i have cablevision box and remote controll for it.
A variety of remote control codes can be found at InsigniaProducts.com. Failing that, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
Posted on Jun 17, 2010
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
Can't program comcast remote to yamaha yas-101
The only thing i was able to do was to use this link and make the remote learn the functions by following the instructions on the Yamaha web site for the sound bar to AUX. YAS 101
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/
I then used the instructions below to volume lock the aux so that i did not have to switch back and forth from cable to aux to adjust volume and change channels
Setting Global Volume Lock
Global Volume Lock will force the volume and mute keys to be controlled by one device.
  1. Press and hold the "Setup" key until a device key blinks twice.
  2. Type in the code 993. A device key should blink twice.
  3. Press and release the device key for the device you want the volume locked to.
  4. You will get two blinks if the lock is successful.
Jul 03, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
My comcast remote won't turn on or off my yamaha rxv365 audio receiver only controls the volume the code i put in was 30176
It controls the volume just fine. It's the power that doesn't work. I'm having the same problem with my Yamaha receiver. Different model. Multiple Comcast remotes too.
Apr 14, 2011 | Yamaha RX-V363 Receiver
My harmony 520 is set to control the onkyo receivers volume but changes the volume on the tv.
Learn the volume commands for your TV and Receivers. This will resolve your issue. Please see the link below.
Learning in RAW--
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3859
Jan 07, 2010 | Logitech Harmony 520 LCD Remote Control
Remote does not move volume knob
Unplug the receiver for a minute then plug it back in. This resets the controls. If you still have a problem, post a comment and I will help you troubleshoot further. Hope this helps
Jun 25, 2009 | Yamaha RX-V800 Receiver
Volume control on unit
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Sep 14, 2008 | Yamaha HTR-5550 Receiver
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
DirectTV HD-DVR & Yamaha RX-v1500
The types of remotes are as follows
- Single item, or fixed. This unit will only operate the unit it came with
- Multi function, this type can operate the unit it came with and a fixed set of other types. Normally the remote comes with a list of supported device it could work with.
- Learning, the combine both a predefined list with the ability to learn functions by sensing input from the original remote.
- Programable. These are the newest remotes that work like multifunction but the list is maintained by the manufacturer and down loadable from the web.
I would guess that the DVR has a multi function remote.
If you can't find the specific Yamaha in the list, then
try another brand, this could take a while.
Some multi function remotes have an option that allow a semi automatic configuration.
You turn on the item and then using a special key sequence try to turn off the device. once the item turns off you should be able to control it.
If you can't the Yamaha has a learning remote. If you really want an easy solution try looking at a programmable remote. I just got a Logitech, (Harrmony). Life has never been so easy.
Mar 08, 2008 | Yamaha RX-V1500 Receiver
Sylvania 6615LE LCD HDTV Logo
520 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
