Question about Garden
Problem aligning the adjustment block of chain tensioning screw
I have a remington 1.5 hp electric chain saw - moedl # M15014AS. The manual says to put the sproket cover back on and then line up the adjustment block on the chain tensioning screw into a round hole on the guide bar. I can't see anything once the sproket cover is back on, so I'm having zero luck lining up the adjusting block into the hole.
  • 10,865 Answers
Line up the adjustment block and put the screw into the hole. then carefully snug it down and put the cover back.
Posted on Sep 07, 2009
I think I am missing a part for my Remington lnt-2 12" chainsaw
You do not give us a model number to verify this will work on your saw.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the "YourModelNumber" - Remington Electric Chain Saw "View Model" link.
  • Click "View Owners Manual" or "View Illustrated Parts Diagram" link.
    • Type "YourPartNumber" into the "Search for your parts by Part #:" window, then click search.
A tension repair kit is available here:
MasterParts.com
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=108640-MD
Part number 108640-MD; DESA SPECIALTY PARTS: KIT, ADJUSTMENT SCREW FOR SPROCKET COVER (REM-18); $5.95.
Kit fits the following covers: 108640-01, 116675-01 and 108641-02 (note: for the 108641-02 the screw will adjust from the front with a screw driver, not with a thumb screw at the back) KIT INCLUDES: screw, clip & adjustment block.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 21, 2010 | Remington Electric Chain Saw
Does a Remington 3.0 HP 300 with #114732-01s have a chain tension and screw. I do not have the manual and can not see where a chain tension screw would go.
The part number is Remington's and cannot be interpreted. What is the saw model number (reply below please)?
See the 2 holes near the heel of the bar (each side of the slot)? That is where the adjuster fits. I do not recall any Remington with an "Intenz" type bar (tensioner embedded in the bar).
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Remington Electric Chain Saw
Unable to find place to buy chain adjuster.
Lou
I have a Remington 16" (107625-01)
The nib broke off of the block adjustment and it was bent anyway.
Where did you find item 26 and 27 above?
Thanks Daryl
Jan 29, 2010 | Remington Electric Chain Saw
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
Oil
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
May 25, 2009 | Remington Electric Chain Saw
Remington M15014AS Chain came off and I have no owner's manual
Here is a link to the instruction manual for a M14SC (the part number for the chain that will fit your saw) chain installation ... http://12.153.20.74/manuals/115038-01A.pdf . I hope this helps... If you need further instructions you can go online to http://www.remingtonchainsaw.com/.
Apr 19, 2009 | Remington Electric Chain Saw
Need to clean out chain saw sprocket area
Hi dorothy. Here is the link to give you a free manual that will give you all of the info u need.
http://www.remingtonchainsaw.com/chainsaw.html
Mar 14, 2009 | Remington Electric Chain Saw
What type of oil do I use for a Remington Electric Pole Saw?
Mar 13, 2009 | Remington 16" Electric Chain Saw
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
