Washer runs and does all functions except spin. i have it apart but dont see a belt. is it contained in its own cover
  • 574 Answers
Probably isnt one look for a coupling on the end of the motor shaft next to the tub
Posted on Sep 07, 2009
I have a GE washer model wwse3160a. It does not function except it fills with water. I checked the drive belt, I tried turning the motor clockwise and it spins the drum. All the lights come on but it...
Hello
I am familiar with this problem and 99% of the time it is caused by the washer lid safety switch, if the switch doesn't function the washer control will not let the cycle run past filling the tub with water. You can buy the part and get information on how to install it from a company called www.repairclinic.com
Sep 14, 2011 | GE WWRE6260D Top Load Washer
I have a GE Mod. WJRE5550H1WW washer. It appears that all the functions work except the spin cycle. Is there something I can do ? The machine is just over two years old. Thanks for...
The drive belt may have been broken, worn, or has slipped off. Reset the washer then restart a new cycle and check if it will tumble or not. The belt is indeed not in good operating condition should the washer seem to complete the wash cycle but does not tumble or spin.
Unplug the washer for 2 minutes then plug it back in. Open and close the lid seven times to reset the motor and the inverter.
The inverter on the top of the motor flashes a code to indicate a fault. Take the washer front panel off to access the motor and the inverter and see the blinking LED. Look into the seam where the top meets front panel. There is a clip on each side; push a flat head screwdriver into the clip to release it Pull the top of the front panel and slide it up to remove it. Check belt and the LED for the code. Black powdery substance at the base of the washer is a sign that the belt is worn; replace it.
May 25, 2010 | Washing Machines
Washer will not spin
Hi, If it doesnt spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Motor seems to run but won't agitate or spin.
Dont take it apart you dont know enough to do that safeky!
It could be the pressure switch and or hose. Put that to a local techo and see what he offers to charge to fix it.
Oct 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Magic Chef Washer will not Aggitate / Spin
The best thing to do at this point is to get back to the belt and inspect everything, this can normally be done by unscrewing the back panel. It may also open from the top, not exactly sure. Always call a pro if you dont feel comfortable doing any repairs yourself.
Sep 23, 2009 | Magic Chef CAV4000AWW Top Load Washer
Frigidaire Galleria Front Load Washer.
Could be anything from lid switch to pc board to belt tensioner. Start with the cheapest and easier first with lid switch and belt tensioner.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
2320l hoover washing machine wont spin fast to dain all water ...on any program ...all other things ok ...can hear grinding noise when washing ..dont use machine at moment ..like metal rubbing:)
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
May 23, 2009 | Washing Machines
My aquarius wma40 hotpoint did not/will not run a spin slow/fast
Sounds like a belt. I would proceed to take apart whatever is needed to get to the pulleys and replace the belt. Did I address your question?
May 07, 2009 | Hotpoint WMA40 Front Load Washer
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
