Question about Sceptre x22wg Gamer Monitor
X22WG-gamer sceptre 22" monitor won't power on. It's not the power cord because I've used the power cord on a different monitor and it worked fine. Any and all assistance will be much appreciated.
  • mmmike529 May 11, 2010
    i've got the same issue with my x22wg. powers on, but shuts off in less than a second. i have no problem working with the caps, but i've seen too many cases damaged by prying them open...i don't want to damage mine...what's the procedure for separating the front and back? is assume there are specific places to put a tool to do without gouging the **** out of it? thanks
Your monitor has 3 or 4 blown caps right next to the power plug. They are CapXon 470uf25v. Just open the back and remove the power board, desolder, and replace the 3 or 4 caps put it back together and it should go back to working. This a typical problem with the Sceptre gamer, HP1706, and the HP1903. And guess what they all have the same caps blown in almost the same place.NOTE: When seperating the case the power led is glued to the front frame. Take your time if you rush you will break a cable wire or plug.
Posted on Oct 09, 2009
I have two of the X22WG monitors, both dead. The power supply in this model is not as described above. There is one big cap (C114) which is ok, but instead the problem is close to the +5V and +12V output connector (Far right corner, with power plug against you). Two out of the four small caps are blown. Replace those, and it should be fine.
Posted on Jan 11, 2010
My sceptre x22wg monitor has recently been turning off when turned on, how can i fix this? i use this for a dual monitor setup so this is very frustrating to me
Make sure windows finds your monitor in your OS(operating system) Start<My Computer< right click on my computer and click properties< device manager < goto Monitors and see if windows finds it. If you have a graphics card, make sure the card has the latest driver installed from the webite.
www.nvidia.com www.ati.com
Jun 05, 2011 | Sceptre x22wg Gamer Monitor
My sceptre X22WG is no longer showing white screen but getting progressively darker blue. How can I get it back to a white screen?
Colour changes like this are either due to a failing graphics card, failing monitor or bad connection from the computer to the monitor.. with this monitor, I'd have it checked by a tv repairman
Jan 18, 2011 | Sceptre x22wg Gamer Monitor
X22wg-Gamer Monitor: It appears the power supply is dead, what can I re...
you need to check if your capacitors are blown, if they are, you can replace them...it's a very economical way of fixing it. This is a common problem of Sceptre x22wg-gamer.
May 16, 2010 | Sceptre x22wg Gamer Monitor
Monitor will not turn on blue light flashing bottom right hand of monitor
I'm having the same problem. Had the monitor for almost 2 years and everything was working fine until this week. The blue light would blink, then after an unpredictable period of time, the monitor would turn on. Seems like it needs to warm up or something. I suspect it has something to do with the capacitors not charging inside. Somewhat disappointed with Sceptre. I suppose I should be thankful that I got 2 years out of it.
Oct 09, 2009 | Sceptre x22wg Gamer Monitor
Monitor worked fine for years, then permanent standby
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sep 18, 2009 | Sceptre x22wg Gamer Monitor
My Sceptre x22wg-Gamer Monitor isn't getting any power, HELP!!!
I have two of the X22WG monitors, both dead. The power supply in this model is apperently plauged with a common error. The problem is close to the +5V and +12V output connector (Far right corner, with power plug against you). Two out of the four small caps are blown. Replace those, and it should be fine. C551 and C552.
Jun 09, 2009 | Sceptre x22wg Gamer Monitor
Screen is covered with horizonal multicolored lines.
1st and least expensive is to replace the video connection cable. Try that
Cheers!
Mar 26, 2009 | Sceptre x22wg Gamer Monitor
Help! Any assistance or advice would be very much appreciated. I have a Sharp LL T19D1-B LCD Minitor purchased a little over 3 years ago. I had a mac plugged into one analogue input of monitor, screen...
This is the power supply inside the monitor itself. It is board that has three capacitors and they are blown out. It is a very inexpensive fix, if you are good with a soldering iron, if not let mw know and I will direct you to a company that can take care of this, for usually $30.00
Sep 26, 2008 | Sharp Computers & Internet
Sceptre x22wg Gamer Monitor Logo
1,425 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
