Question about Canon EF 100-400mm f/4.5-5.6 IS USM Lens
My canon 100-40mm lens will not release from the camera body. The lens nor the body has ever been dropped. Yesterday afternoon while I was using it along with my canon 70-300mm IS I had no problems whatsoever switching in between. Any thoughts about what could be wrong and what can be done to remedy the problem.
  • syko125 Sep 07, 2009
    I just tried removing the battery and it had no effect. However to answer question I'm using a canon rebel xti.
    Brigadier General:
  • 4,090 Answers
Lens is cross linked in the mount.
You did not say anything about the camera body or the model. Try removing the battery first to see if the auto mount mechanism will release it.
Please rate our help to keep the FREE service online++++Thank you for using FIXYA
Posted on Sep 07, 2009
52mm lens stuck on body,,how do you unstick it?
Normally, these lenses do not 'unscrew'. When you push the red button, it releases the lens catch and then you rotate the lens a short ways counterclockwise, then gently pull forward on the lens while holding the body of the camera and the two units separate. It is possible you have gotten some dirt into the lens latching mechanism. Try returning the lens to the locked position, press the red button, rotate the lens to where it stops and then returning the lens to the locked position and repeat several times if the lens does not lift out when you hit the movement stop. This may allow you to get past the dirt. Otherwise, take it to a camera shop, particularly if the camera is still under Canon warranty.
Dec 04, 2014 | Canon EOS 550D Rebel T2i Digital Camera
Why is my canon xsi suddenly not auto focusing?
Try removing the lens with the camera off and re-mounting it. Before doing so, check to make sure the contacts on the lens and camera body are clean and not damaged. If that doesn't help try gently pressing on the front of the lens (not the glass) while pushing the shutter release button half way down and if it works then you've got a poor fit between the lens and camera body.
Aug 16, 2014 | Canon EOS 450D EOS Rebel XSi Digital...
I have a canon eos Rebel DXS - I dropped it and now it won't focus.
Normally I'd say your camera is due for a trip to the service department but, depending on the surface the camera was dropped on and did it hit lens first or body. So without knowing let me ask you to do this. Remove the lens and quickly install the body cap on the camera. Hold the lens firmly in a hand and shake it vertically gently but with a little vigor listen for a rattle, stop, do it again horizontally listen for a rattle. If it rattles the lens has internal damage if not and the camera appears to be functioning then I'm going to instruct you on how to clean the gold contacts on the lens and body.
Using a new pencil with a red rubber eraser gently rub/clean the gold contacts while holding the lens almost vertical with the contacts facing down, use a puffer/blower to clear away the rubber dust. On the camera body, remove the body cap and hold the camera with the lens mount facing down as best possible and clean the tinny gold contacts with the red rubber eraser. DO NOT use a puffer/blower or blow on this part to remove eraser dust. Keep the camera lens mount facing down as much as possible and use a lens tissue to clean away any rubber dust. When you have completed this install the lens on the camera and make sure it clicks and locks solidly. Try your camera again, if it works great if not it means there is an electrical break within the camera or lens and it needs to got to a service depot. Hope everything work for you
Jan 02, 2011 | Canon EOS Rebel XSi Digital Camera
Dropped my canon t70 and the lens is all broken; can it be repaired if the body is still working fine?
The lens should be removable
See attached page
http://en.wikipedia.org/wiki/Camera_lens
I am not familar with your exact camera, but I would suspect you have what is call a bayonet mount.
Look for a button around the lens in the body, push it, twist the lens.
I have acouple old lenses from my Alpa 9d (Dead) will they fit?
Mar 08, 2010 | Canon T70 35mm SLR Camera
I dropped my Canon EOS Rebel Xti in the canal while kayaking.
Water in the camera body could take up to a week to dry. If you tried turning it on while it was wet inside, you may have shorted out some circuits.
Aug 23, 2009 | Canon EOS 400D / Rebel XTi Body Only...
Error 99
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Mar 16, 2009 | Canon EOS 40D Digital Camera with 17-85mm...
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
50mm C lens issue
From your description, Yes. All RB67 lenses have common problems, usually sticky blades. Since there are 2 sets of blades, (shutter and aperture), the shutter blades may be contaminated with oil/debris
Apr 19, 2008 | Mamiya RB67 Pro SD Medium Format Camera
AF and shutter release failure
There was a lot of discussion of this when the Mk II was new. Many people "fixed" it doing just the things you did. Also, some reported that mounting the lens on another camera "fixed" it. IIRC, in the end it ended up being a lens issue. IS module. Canon can repair.
Mar 19, 2007 | Canon EOS-1D Mark II Digital Camera
IstD shutter release problem
I've had similar problems with my Pentax Super-A on an intermittent basis. If you haven't replaced the batteries I suggest you try that first. Not sure why, but that has sorted my problem out quite a few times (even when the existing batteries still have a fair amount of juice left in them).
Sep 08, 2005 | Pentax *ist D Digital Camera
Canon EF 100-400mm f/4.5-5.6 IS USM Lens Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
