Question about Kodak EasyShare Z740 Digital Camera
Formatting memory card
When I try to format my memory card it comes up with the message "Read only memory card, removee write protection to capture or write to card" it even says this when I try to put a brand new card in.
  • jcork132 Sep 07, 2009
    This did not help even though the switch on the memory card is in the correct position I still keep getting the same message.
  • 739 Answers
Normally that means your card is locked.
Look at the side of the card, there is a tiny switch - this is the write protection switch.
You may be catching it accidently with a finger nail.
Posted on Sep 07, 2009
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Card can not be formatted
There is a write protect switch on the side of the card. That may be the reason why the comp is unable to use it.
Jun 05, 2009 | SanDisk 4GB Secure Digital High Capacity...
Formatting
Hello Laurakeeney1
I would check to make sure your SD card in not Set to Write Protected, if it is not follow this link for a Flash Memory format utility that I use to fix any problems i have with Flash memory
HP USB Disk Storage Format Tool - v2.1.8
http://files.extremeoverclocking.com/file.php?f=197
Hope this Helps
May 05, 2009 | SanDisk 2GB microSD Memory Card
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
SanDisk 2GB microSD error message - Disc is Write-Protected
Re-format it. Put the SanDisk 2GB microSD memory card into your LG enV2 and format it from there. If that does not work plug it into your laptop then right click the icon and format it to FAT and click on default settings.
Sep 21, 2008 | SanDisk 2GB microSD Memory Card
AIPTEK IS-DV2
First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
Jul 08, 2008 | Aiptek IS-DV2 Camcorder
SanDisk 1GB microSD Memory Card
The write Protect tab, is usually write protected with a small white plastic flick switch, On The side Of the SD Card. If its Down, or In Lock Position. Then It,s Write Protected.
Mike @ compurepair.
May 10, 2008 | SanDisk 1GB microSD Memory Card
"Memory card cannot be read"
My camera used to do the same thing--once I got the pictures off my card, I left it in the card reader, right clicked on removable media (my computer + removable storage) chose to "format" and formatted it on my computer. It seems to have fixed the problem, and my camera now reads it fine. I tried to format it on the camera before, but it didnt work.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
56 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
