Question about Maxtor Hard Drive
My external hard drive was called 'f' and has itunes music paths linked to this but for some reason it has been re-named as 'g' so i can't link any music to it... any ideas? thanks
shadow5599
  • 51 Answers
SOURCE: exturnal hard drive fell
The fall was probably too much for it. If it was powered up at the time of the fall and the fall caused a substantial shock, it is most likely gone. A running hard drive cannot take much shock.
Before giving up on it, if it was mine, I would remove the hard drive from the portable case and plug it directly into a computer either through a USB adapter, directly to a motherboard or any other available method you may have.
The purpose of that is to bypass the case's electronics and deal directly with the actual hard drive.
If it wont read from it by doing that, you are done.
You could try a warranty claim if it's new enough.
If your data is extremely important, you can send it to a data recovery service but the costs are high. $500 or $1,000 for data recovery isnt that unusual.
Re-post here, let me know how it goes.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Posted on Oct 18, 2007
TakeTechsol
  • 3 Answers
SOURCE: simpletech 500 external hard drive
hi
your usb cable may be faulty so replacing it may solve problem
Posted on Jan 08, 2008
SOURCE: I can not link up with My Book World Edition 500GB
That is because the MyBook is set with a default IP address of 192.168.1.257. You will have to put a static IP address in that subnet range in order to be able to see the external drive. Hope this helps....
Posted on Dec 19, 2008
thetez
  • 32 Answers
SOURCE: itunes can't find files
you have to go to the preferences and change the directory where it looks for its media. OR import music from the file(i think) menu [drop down]
I stopped using itunes, but i believe its the first drop down menu.
Posted on Feb 24, 2009
Crankstart
  • 696 Answers
SOURCE: Need to designate default lettering to my hard drives
There is a way to designate drive letters but you will actually have to set all of them to ensure they don't interfere.
If you are in Vista:
open your start menu and right-click "Computer", when the grey menu pops up, left-click the manage link.
a small security window will likely pop up as you are entering a secure part of windows, just click continue and the management console will open.
click on "Disc Management" on the left side and look at your drives. If they're different sizes they'll be easier to identify, if they are the same you will likely have to go into "My Computer" and make note of which Drive letter is the iTunes drive.
On each of the external drives that are not the music drive:
Right-Click the drive(noted by current letter) on the main part of the window and select "Change Drive Letter and Paths" a small window will open. Click the "Change" button, another small window will open with a drop down box that has the current drive letter highlighted, Click the drop down arrow and then click a high, unused drive letter like X or Z.
Repeat with the second drive using a different letter, then
Again with the music drive selecting G as the drive letter.
You shouldn't have to reboot but should you ever add another drive you may need to do this again. So you may want to print these instructions for future reference.
If you have a different version of Windows just let me know and I'll pass on the slightly different instructions for that version.
Hope this helps FixYa,
Chris
Armor-IT
Posted on Apr 26, 2009
I have just purchased an external hard drive for my mac as it is now full. its a toshiba store.e canvio. i have just transferred a movie from iTunes to the drive but it will not play and says file is
This may be a permissions problem. In finder, click on the file, then go to File:Get Info (or type <command>-i). In the file info window, look for "Sharing and permissions." Click on the triangle to expand. Look for a padlock icon, then click on it and type in your administrator password when it is requested. Now you can change permission from "No access" to "Read Only" or "Read and Write."
If this is not available, you've run afoul of iTunes copy protection, or iTunes is not set to look there for files. In the first case, you'll have to work from inside iTunes to get a viable copy onto the external drive, perhaps as a backup copy. In the second case, you would open Preferences in the iTunes menu, then click the Advanced tab to get to the iTunes media folder location dialog. (Make sure the external drive is connected before opening Preferences.) Click "Change..." and browse to the proper folder on the external hard drive. You will have to change back to the original location if the external drive is not connected, so first copy the original location path name and paste it on a Stickies note. After you set the external location, do the same with that path name. Then instead of having to navigate to file locations every time you change, you can just copy the path from the Stickies note and paste it into the location box.
The preceding paragraph was written for iTunes 10.6.3. Your version may differ somewhat.
Aug 27, 2014 | Apple iMac Computers & Internet
Tip
Restoring your iTunes Library backup
When you need to restore your backed up iTunes Library from your external hard drive to your computer, follow these steps:
Quit iTunes.
Locate your external hard drive.
Mac: On the Desktop or Finder sidebar.
Windows: In My Computer
Drag the iTunes folder (backed up earlier) from your external hard drive to whatever location you desire on your internal hard drive. It is recommended that you choose the default location for the iTunes folder, which is:
Mac OS X: /Users/username/Music
Windows XP: \Documents and Settings\username\My Documents\My Music\
Windows Vista or Windows 7: \Users\username\My Music\
Open iTunes while holding down the Option key (Mac) or Shift key (Windows).
In the resulting dialog, click the Choose Library button.
Select the iTunes folder you just moved to the internal hard drive.
Click Choose.
on Apr 15, 2010 | Computers & Internet
Tip
Make a back up of your music on an external Hard Drive or Flash Drive
Copy iTunes folder to your external hard drive
To copy all the items in your iTunes library (including the iTunes Library file that holds all your playlists, playcounts, ratings, and other data) to your external hard drive, follow these steps:
Quit iTunes.
Mac: On the desktop or Finder sidebar.
Locate your iTunes folder:
By default, the iTunes folder is located in:
If the iTunes folder is not in the default location listed above then you can find where the iTunes folder is located by following these instructions:
Open your iTunes Preferences:
Mac: Choose iTunes > Preferences.
Windows: Choose Edit > Preferences.
Click Advanced.
The location of your iTunes folder will be listed in iTunes Media folder location box, as pictured below.
Drag the iTunes folder to your external hard drive. This can take a while if you have a lot of items.
When the transfer is complete, your iTunes Library will have been successfully copied to your external hard drive.
I have transcend storejet elite 500GB. It works well, but the thing that I don't satisfy is that when I transferred the data from my laptop to it, it was not able to transfer the data, it sow an...
Greetings,
That's a good one :). Basically, I believe it's complaining about the path of the file, not necessarily the name. To backup your files here's what I'd do:
1. Grab the files you want to grab.
2. Make a folder on the root of the laptop called "backup".
3. Move/Copy the files you wish to backup into this folder.
This may work because the other path would be something like
c:\Documents and Settings\username\Desktop\folder\folder2\myfile.pdf
or for Windows 7
c:\Users\username\My Music\iTunes\My Media\Music\artist\album\track1.m4a (for example...see where the issue lies?)
Thanks,
cyan990
Jun 03, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have uploaded everything on my Mac laptop hard drive to my SimpleTech external hard drive. I removed most of my music (in iTunes) and some other files to make room on my Mac. Now I'm having trouble...
You may need to tell iTunes where your iTunes media folder location is. You can do this in iTunes, go iTunes>Preferences>Advanced Tab>Change button, then navigate to where your iTunes media is and choose this as its location.
Feb 16, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Itunes on external hard drive
If you want to move itunes to an extrnal driver, ..plug in the external, click my computer..open the local driver, look for " my music icon" and scroll it to the extenal driver icon...or right click the " music and where it says save..save to external driver.
Jul 03, 2009 | Western Digital My Book Essential Edition...
I cannot find the music exported by EZ audio converter
music files converted by ez converter cannot be find in i tunes library because of the incompatibilty of codecs of ez converter and i tunes.try the converters that are compatible with i tunes.
keep updated.thanks and plse do rate this solution.
Jun 18, 2009 | ION Audio iTTUSB Turntable
Chris
Armor-IT
Apr 25, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Backup iTunes Library to external hard drive?
Just take Backup of iTunes Music folder. The Path is C:\Documents and Settings\USER\My Documents\My Music\iTunes\iTunes Music
Dec 09, 2008 | Apple iTunes
Maxtor Hard Drive Logo
76 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
