I have a mitsubishi video scan system tv model no. vs-505u and i hooked up my dvd or my ps2 to it and i have sound but no picture its fuzy and it has lines going back and forth i dont know why
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
  • 25 Answers
SOURCE: help hooking up tv to surround sound system with dvd player
with my Ws-65513 I run only right and left channel down to the aux from there your dolby 5.1 should doe the rest .most systems have center (speech) (R.front) (Lfront)(R.rear)(L,rear) and SW .center you want on the bottom or the top of your screen ,The SW you want Ever behind your set or under your couch.LEFT AND RIGHT REAR YOU WANT SOME WHERE BEHIND YOU OR AT LEAST 90% TO WHERE YOUR SITTING NOW THE FURTHER YOU SET THE REARS BEHIND YOU THE MORE DELAY YOU SHOULD HAVE ,THERE IS AND ADJUSTMENT SOME WHERE BETWEEN 10-30 MIL-A-SECONDS THIS GIVES A SLIGHT ECHO FROM FRONT TO BACK..
i HAVE AN AIWA AMP RUNNING A 12INCH FISHER,CABINET BOSE,AND A PANASONIC SUROUND AS MY FRONT, LEFT AND RIGHT STACKS.WITH A JBL CABNET AND PANA CENTER FOR SPEACH .THEN LET THE REAR GET BOOSTED WITH THE PANA SUROUND SYSTEM BECUASE i NEEDED AT LEAST ANOTHER 120 WATTS TO RUN THE THE JBL12,WITH A PANA SUROUND AND A SUPER TWEET WITH A I/2 POUND MAGNET AS MY L AND R REAR,
THE ***** IS WHEN IM RUNNING MY LOWLY 44 DOLLOR PHILLPS WITH A SEMI 10801 ,I CANT GET MITS SPEAKERS ON LINE,THERE IS ONLY ONE INPUT.wHAT YOU REALY WANT TO DO IS HAVE NO DELAY ON THE CENTER,THEN 5MIL TO YOUR MIT SET SPEAKERS.YOU WILL GET AUTOMATICLY IF YOU SET THE TV ON SURROUND,PUT ONLY KEEP AT 1/4 VOLUME OR YOU WILL SCREW UP THE WHOLE EFFECT HAS THE JUICE GOES TO YOUR LEFT AND RIGHT FRONT IT NATRUALLY HAS ANOTHER 3-5 DELAY AND SET YOUR REARS TO A LEAST 20 TO 30 MILL DELAY.iT WILL PUT YOUR LOCAL THEATER TO SHAME.
Warning make sure all your wires are in phase +to possative -to neg not only you get a ping pong effect if you plan push a lot of watts a surge could make you have a very bad day ,most wires are eather colored on the outside or silver or gold on the inside.if you plan on moveing one side away from the compared to the other side its better to increase at the gauge of the wire,or you will never get the balance right and end up throwing your equipment at whatever pissed you off in th first place.
it,s a type of balance of chi ONCE YOU HAVE IT RIGHT,ANY ONE OR THING THAT ENTERS YOUR SPACE WILL NOT BOTHER YOU AS LONG AS TUBES CONVERGE AND SOUND IS
TUNED LIKE A FORK AND IF SOMEONE ***** WITH YOUR SYSTEM THE TUBE IS SO BIG
YOU CAN AT LEAST FIT ONE BODY IN IT ,i THINK THE CASTORS CAN AT LEAST STROLL YOUR PROBLEM TO THE LOCAL LAND FILL.
i KIDDING PUT i LOVE MY SET ,.i WOULD LIKE TO KNOW IF THE NEW BLUE RAY WOULD CLEAN UP THE 1080i ANY BETTER. GOOD LUCK
Posted on Feb 08, 2009
SOURCE: i have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Posted on Mar 29, 2009
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
maatmartin7
  • 1229 Answers
SOURCE: Projection TV, Sound but no Picture
If this Tv is a model year 1996 or 1998, It is quite possible your vertical IC needs resoldered. It is located on the small signal board. This board [quite large anyway] is the board on the left. I don't know the location off hand. The IC has seven pins and located on a heatsink, It is a TDA series. Resolder any and all grounds you see. May as well get the Large Signal board [On the right] resoldered. The other problem would be the P I P board, a small board standing up, that can be removed and replaced. But try the earlier first. This is tedious, but will produce results.
Posted on Jul 12, 2009
How do i hook up my fujitsu laptop to my vs-505u tv
You need what is called an HDMI switcher. It will have one input and two three or four outputs. As many as you need. When you switch devices you just need to hit a button. You can find one of these online or maybe even at a big box store. If you have problems or need to get one ordered message me back or check out our FB site at Connectors Audio and Video Services.
Dec 24, 2014 | RCA Televison & Video
How do I hook up a dvd player to vs 4544?
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
May 29, 2012 | Mitsubishi VS-4544 45" TV
When I hook my dvd player up using the Component Video Input I get sound, but no video. Its not the dvd player because i hooked it up to my other tv and it worked fine. Thanks for any assistance
This might be the other TV's Video Input Cable Plug. Could be disconnected somewhere within, it may be disconnected. If your TV has two slots for Audio/Video Input, try using the other Slots maybe. :)
Apr 02, 2010 | Mitsubishi VS-60607 TV
Trying to hook PS2 up
u cant play them on it its a dvd player
Dec 12, 2008 | TruTech PVS12701 Portable DVD Player
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Hooking up Playstation 2
first, run your playstation 2's video and audio outputs to the inputs of the receiver. Choose whatever source you want, for example, DVD, VCR, or Video 1, 2, or 3.
Then, run the Monitor Out output on the receiver into your Video Input on your television.
Whatever source you hooked your PS2 as (ie DVD, VCR), select that source on the receiver. You should hear sound at this point.
Then select the video input on the TV that you hooked the receiver to. You should see video.
This will allow you to use the receiver as a switcher for both audio and video.
Jan 27, 2008 | Onkyo HT-SR800 System
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
May 30, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Sound but no picture...
sir i think it needs warm up or clean it,,,,or try too adjust its screen fucos thankss and hope to help you,,,gud luck
Aug 02, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Open Questions:
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
