Question about Karcher 2500 PSI Pressure Washer
Karcher G3050OH Pressure Washer Spill / Unloader Valve (Bypass)
Karcher G3050OH Pressure Washer horizontal mount 3000psi the Spill / Unloader Valve (Bypass) which is a 3 piece assembly with a male, a female and a spring betwwen keeps backing off from eachother releasing the spring and shutting the pressure down. I have put it back together several times what gives is this normal or have I failed to adjust it correctly?
    Problem Solver:
  • 6 Answers
You should put 'locktite' on the male thread and screw it in all the way and lock it there. That is how it works ,the spring keeps the valve at the bottom closed during high pressure operation. When the gun is released the part with the o-ring is forced down resulting in the valve opening and then the pressure is by-passed.Those dont normally give trouble. Look for a blocked nozzle or a restriction somewhere in your high pressure hose.
Posted on Sep 08, 2009
What is spill valve in karcher 502
Another name for bypass or unloader valve. This is a safety device for your pump head for when the pressure gets too great or water temp too hot they are pre set to dump water and prevent damage to the internal valves and seals hope this helps!
Brad
Jul 05, 2014 | Karcher 2500 PSI Pressure Washer
What is a bypass unloader
According to epowerwash.com:
"The unloader valve diverts water flow into bypass when the trigger gun valve is closed. Unloaders may be designed to respond to either an increase in pressure or a change in flow. The unloader valve may also be used for variable pressure adjustment."
More information here:
All About Unloader Valves ePowerWash
Jun 06, 2014 | Alfred Karcher Pressure Washer
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
Lost pressure let handle go spits out 1 second of pressure then no pressure
What you are describing is an unloader valve failure. The unloader valve (also called a spill valve or safety pressure relief valve) is sticking in what is known as bypass. Your pump is able to build pressure but when the trigger is squeezed, rather than directing the flow up to the nozzle it is looping the pressure back through the pump as it does when you release the trigger. Depending on the specific brand and model you will need to either replace the unloader or lubricate it if it is a Karcher with a spill valve. If it is a Karcher there is a known issue with the following models:
K2300G1
K2400HB
K2400HH
K2401HH
K5800G
K5800G
All of these have an issue where the spill valve sticks and will need to be lubricated with Vaseline or lithium grease. You can view a guide for this process at http://www.landanorthwest.com/dms. Select Maintenance/Karcher/Pressure Washers/All/Spill valve lubrication.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 08, 2011 | Ridgid Diehead Complete 11R 12 NPT
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
We have a Karcher G2500VH pressure washer. If you start the engine with the trigger pulled on the spray wand it will run at full pressure until you release the trigger. after that, when you pull the...
Hi, Karcher calls the unloader valve a spill valve,
this is a link to a full drawing/parts listing , and your fault description might well be a sticking /seized unloader(spill ) valve hope this helps
http://www.pressureparts.com/ManualViewPage.aspx?Manual=/mmDEV/PDF/karcherparts/g2500vh.pdf
the part number is on page 9 of the drawing
spill valve 45910400
hope this helps , we usually use some good quality silicone grease to lube the valve ,
Mar 07, 2010 | Karcher 2500 PSI Pressure Washer
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
No pressure / Karcher G 2400 HH
Hi ruthkapres:
Here is a diagram. The unloader/spill valve is #12 on page D2 or F2 depending on your model. You must pull it out, inspect the o-rings for dents or tears and make sure the valve is lubricated with a good water proof lubricant.
Jul 14, 2009 | Karcher G3025OH Pressure Washer
How to clean unloader valve..
The Karcher K2400HH and G2400HH do not have an unloader valve, they have a spill valve which is located under the black cap on top of the pump.
The spill valve needs to be removed and the side walls of the hole it sits in need to be wire brushed to remove deposits. then you can put it back in and put the pump back together.
Jul 03, 2009 | Garden
Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Jan 11, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
935 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
