Question about Acer Aspire 3690-2196 Notebook
How to connect my phone to my acer 3680-2682 using bluetooth device
  • pttjunior Sep 08, 2009
    thanks rayman but you see there is no blue tooth devices on my window vista control panel
    Problem Solver:
  • 15 Answers
This will only work if your bluetooth device is installed
for windows vista: start / control panel / bluetooth devices. Once open click: devices / add / next / find device / then pair your devices just like you would with two phones.
for windows xp it should be exactly the same, post back if it isnt.
Dont forget to rate me, raymond.
Posted on Sep 07, 2009
Testimonial: "thanks alot i will install the blue tooth device i think this requires drivers"
My biuetooth does not work properly in my acer aspire5750
Activate the Bluetooth features of your Acer Aspire to unlock your laptop's wireless function. Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers.
In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard.
The LED above the button should illuminate.
Click "Start," "Control Panel" and "Add a Device."
Your Acer scans for other Bluetooth devices in the area.
Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Microsoft bluetooth support
http://support.microsoft.com/kb/883259
Aug 05, 2013 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3618AWLCi bluetooth
Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers. In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard. The LED above the button should illuminate. Click "Start," "Control Panel" and "Add a Device." Your Acer scans for other Bluetooth devices in the area. Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Feb 03, 2013 | Acer Aspire Computers & Internet
Hello, I just purchased an acer tablet, and I'm trying to connect and use my wifi from my mytouch android cell phone, but its not connecting. What am I doing wrong?
you cannot connect two mobile devices because that two devices are only receivers so you need a transmitters such as the laptop or a wifi router and then using that you can connect your two devices
Jun 12, 2011 | Acer Computers & Internet
How can I on the bluetooth on my laptop aspire 4743Z?
Connecting your Bluetooth wireless phone with your laptop is called pairing, and I'll use a Blackberry Curve to show you how it works. I'm assuming your laptop comes with a built-in Bluetooth adapter (or you can also get a Bluetooth adapter that plugs into one of your USB ports).
First make sure that Bluetooth is enabled on your phone. For Blackberry phones, that means selecting the "Set Up Bluetooth" application from the main screen, and then selecting "Enable Bluetooth" after clicking the menu button.
Next, set up your computer to allow Bluetooth connections. If your computer comes with Bluetooth, then you'll see a Bluetooth icon in your Control Panel (Start button -> Control Panel from Vista):
control-panel-bluetooth.jpg Double-click the Bluetooth icon and you'll see a Bluetooth Devices dialog. Click the Options tab and make sure the options to "Allow Bluetooth devices to find this computer" and "Allow Bluetooth devices to connect to this computer" are both checked
bluetooth-devices-options.jpg Next, click the Devices tab and then click the "Add" button. This will open the Add Bluetooth Device Wizard, and after verifying that your device is set up and ready to be found (ie. Bluetooth has been enabled on your wireless phone) it will try to find your phone.
add-bluetooth-device.jpg Select the Bluetooth device and click Next to set up a passkey, which is a number that associates your computer with a Bluetooth enabled device. For security reasons, most Bluetooth enabled devices (with some exceptions, such as mice) require you to use a passkey. Using a passkey helps ensure that your computer is connecting to the device that you intended and not someone else's device that is nearby.
You can choose your own passkey or let Windows choose one for you. Click Next and then pick up your phone, which will prompt you to enter in the passkey. After entering the passkey in your phone, Windows will finish the pairing process and your phone will be connected via Bluetooth.
May 10, 2011 | Acer Aspire 5742Z-4200 Notebook
Bluetooth connectivity
i also had the same problem
Apr 22, 2010 | Acer beTouch E100 Cell Phone
How do I bluetooth photos from motarola v3 mobile phone to my pc,
i dont have acess to one of those computers but i will try my best to help you out.
click start, control panel,devices.then see if you find the bluetooth device.
turn on the blue tooth on the phone and use the discoverable function.
use the computer to search and try to connect to the phone.
when it is connected to each other the you can now transfer info.
to send the pics no:-
mark the photos on the phone
select send via bluetooth
search devices
select the computer from the phone
send it
on the computer recieve file and choose save location.
Alternative method:-
some bluetooth devices allow you to search the phone and take any device after connecting to it!!
HOPE THIS HELPED A LITTLE!
Feb 27, 2010 | Motorola Mobility RAZR V3
Unable to use bluetooth
Not all Acer's have bluetooth inside, even though there is a bluetooth button on most modules. I am on my second Acer, you will have to either use a USB bluetooth or install a module yourself, but be warned its not so easy as it should be!
Apr 18, 2009 | Computers & Internet
Problem with bluetooth
HI,
maybe the driver of your bluetooth are not installed properly.
you can try to reinstall it using your driver cd of acer.
thanks,
let me know if any changes happens.
Mar 20, 2009 | Acer Aspire 6920 Notebook PC
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
Files from my phone to acer laptop
Most acer laptops have the bluetooth front button but very few have it installed. No device means yours is not bluetooth enabled and you will have to purchase a usb bluetooth adapter, class 1 being a 10 metre distance connection, class 2 being a 30 metre connection distance.
Apr 19, 2007 | Zoom BLUE TOOTH USB WLS ADPT- CLASS1...
Acer Aspire 3690-2196 Notebook Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
