Question about Dewalt DW364K 7 - 1/4" circular saw with rear pivot depth of cut and Electric brake
I had my dewalt circular saw fixed @ a shop & when I got it back the blade doesn't line up with the front guide ... ?And I tried the adjustments I can only get it a eighth inch from where it should be I think they reassembled it wrong...? Where can I get prints on the saw ... ? Thank you,Brian
    Scholar:
  • 150 Answers
Really it should go back to the shop.
If they refuse to correct see Trading Standards
Posted on Sep 07, 2009
My dewalt dw712 cuts out of square. How do I fix it ?
I've been in construction for 49 years. I never use the guide or laser because there are some blades that are thicker than others, especially the blade that comes from the factory. It is one of the thinnest. I always guide the side of the blade with the line while I am cutting.
May 19, 2014 | Saws
GUIDE DOES NOT LINE UP WITH BLADE EVER AFTER ADJUSTMENT NOTHING SEEMS BENT OR BROKE.
If you have removed the blade, check to make sure that you have assembled it correctly. All the spacers in the right place.
Feb 04, 2012 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
When sawing against a guide the back of saw moves away from guide can not hold it against it. Also center of blade around arbor gets hot and builds up gum. no looseness in bearing and saw turns free???
hi there
this happens alot with circular saws it usually means that the saw is out of alignment back to front this makes it ******* the tool because your going strait and the tool isnt its fighting it self ******* the motor and whole tool this happens easily setting it down hard throwing it in truck with other tools etc.. the olnly thing you can do to fix this is use solid work bench with tool unplugged lift safety set blade up against the bench then measure front and back from the bench this will tell you if its out of line if so you will need to take it to a tool repair shop to get it fixed
hope i have helped you with your problem thank you have a great day
Aug 20, 2011 | Makita 7 1/4" Circular Saw 5007NB
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
How do you lower and raise the blade on my d364 circular saw
There are typically two adjustments on the saw, both of which operate with a wingnut type of screw/bolt. The one in the front of the saw adjusts the angle of the blade (typically front right hand side of saw) and the second, to the rear right hand side of the blade, adjusts the depth of cut by moving the bed (flat part of the saw on the bottom) up or down.
Jun 20, 2011 | Dewalt Saws
I have a DW357 circular saw. It is running backwords???
It shouldn't be for no reason...... Check that the blade is spinning over the top and down into the wood in the line of travel. Is it possible that the blade is on backwards?
Best regards, --W/D--
please feel free to rate this solution. thanks.
Feb 05, 2011 | Dewalt Heavy Duty 7 1/4" Circular Saw
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
B &D saw 5150 is shotting blue sparks. What is the fix?
Check the brushes, clean the commutator with fine sand paper.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 01, 2009 | Black & Decker DeWalt DW9055 5-3/8" x 16...
Dewalt 10" table saw, when ripping jambs @ back of guide?
Without knowing the full problem, (theheader is cut off) I would ask are you using the fence to help you rip? and when does the board jamb? If it jambs toward the back of the saw the guide might not be square with the blade. I would unplug it and put something that you know is square on the front edge of the blade away from the teeth and adjust the fence so that it is just snub then lock down the table and move the square to the back of saw, it should move with no resistance. If it does then the fence is out. What you would need to do if this is the case is align the fence to the blade, on the back of the saw are 2 10MM bolts that you need to loosen put your square at the front again and lock down the handle with that done move the square to the back and tap the rail on the back side to move tighter or looser and then lock down the bolts. What I do is move the fence away and then back and start all over again to make sure nothing shifted. It sounds more involved than it is. Let me know if this cures your problem
Jan 12, 2009 | Dewalt DW746X 10" woodworker's table saw...
Dewalt DW364K 7 - 1/4" circular saw with rear pivot depth of cut and Electric brake Logo
96 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
