My sony receiver will turn on but not work
My sony receiver will turn on when it is plugged in to the wall then start working then is says Protect on the screen? how can i fix this prob
    Novelist:
  • 190 Answers
This "protection" mechanism is causing your speakers to go silent. Check the back of your receiver for loose/disconnected or shorted wires. Your receiver may have a TEST button that will tell you whether there's a problem with your connections.
After having checked/reconnected all speaker wires, run the test by pressing the button. Sound will come from each of the speakers, usually clockwise and go round all speakers until you press the button again.
Should there be a problem, the display will tell you whether the polarity is wrong, there's no connection, etc. If the messages don't make sense to you, go to your user's manual for an explanation.
Posted on Sep 08, 2009
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
Trying to hook up sony s-master with componet cables an the s-master displays on the display ''PROTECT UNPLUG'' however with nothing plugged in the s-master, works fine
Check speaker wires, any wire seems shorted and causing Protect Unplug error message in receiver.
Good way to sort out bad wire is plug one speaker at a time, turn On receiver check, turn Off, then plug next speaker wire until you find out what speaker wire activates protection circuit of receiver.
Thanks.
Jan 01, 2011 | Audio Players & Recorders
On display appears PROTECT. can not clear data. how to solve it? thanks
check all the speakers connections for short circuits
unplug from wall
and
unplug all of the speakers and extra components and turn it on to see if the message disapears
if it does one by one start plugging that speakers back in
unplugging from the wall every time you add a speaker
(just in case the reciver only realises there is a problem after it shuts down)
if you find that after pluging in a speaker and when you turn it on check the wires for cuts or short circuits and check the speaker itself replace it with another and see what happens
May 10, 2010 | Sony STR-DE597 Receiver
The receiver problem
First thing I'd do is unplug it from the mains and check every speaker connection for short circuits (wires touching) Alternatively, disconnect all speakers and plug in a set of headphones to see if the Protect goes away. Check all components plugged into the receiver by unplugging then one by one. Finally if the Protect is still alight disconnect absolutely everything with the receiver volume control on zero. pull the plug out of the wall and let the receiver sit there for an hour with nothing connected. Then plug it back in plug in your headphones switch the receiver to FM and see what happens. If the protect is still there then I'm afraid the repair shop is your next stop.
BUT check those speaker wires especially if you have puppies or small dogs or believe it or not a small child. They tend to chew on things when teething.
Apr 07, 2010 | Sony STR-DE325 Receiver
Sony DE-445 reciever flashes PROTECT
Sounds like a grounding problem. If the ground plug isn't missing or loose try plugging it into a different outlet.
Jun 13, 2009 | Sony STR-DE445 Receiver
RC cable in headphone jack then to power source now ''protect''
This generally means that you've got a short somewhere.  You most likely *don't* need to bring it in for repair.
If you're familiar with how your system's set up, do the following: 1) Unplug the receiver from the wall. 2) Unplug your gear from the receiver 3) Plug the receiver back in 4) Plug each individual component into the receiver, and test it as you go.
The "protect" is there to protect you from damaging your system, which is why it still works (sort of.)
If that solution doesn't work, check all your speaker connections.  One may have come loose, and you've got positive and negative connections touching each other.
Mar 18, 2009 | Sony Audio Players & Recorders
Sony STR-D665
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Sep 16, 2008 | Sony STR-D665 Receiver
Works, but goes into protect when you turn up/down volume
If its new call Sony and get service????????????
Aug 28, 2008 | Sony STR-DE445 Receiver
Need help
Have you connected an extra pair of speakers?. (Thereby loading the amp stage beyond it's capacity)
Are the speakers connected to the unit the original ones the system came with or different? ( Speaker impedance, usually displayed at the back of the speaker cabinet must not be less than amp's specifications....6 ohms, 8 ohms)
If you're driving the unit excessively you're lucky this piece is equipped with protect mode, else your speakers and amp would have been fried by now.
One last possibility comes to mind: High volume causes vibration causing loosely fitted mains plug to rattle in wall socket calling "protect" due to improper feed voltage. Move the unit to another wall socket and ensure a tight fit into mains receptacle.
May 20, 2008 | Sony STR-DE197 Receiver
87 people viewed this question
 Grubhead
Grubhead
