Question about Acer Computers & Internet
My Acer BL51 shuts itself off after about 15 minutes, then it usually has to cool down to start again. I spray canned air into the vents on the bottom, I can start it again right away.
    Genius:
  • 1,027 Answers
Check the cooling fan; it is probably bad.
Posted on Sep 07, 2009
Air conditioner cools for 30 minutes then stops cooling after 20 minutes starts cooling again what is likely problem
The compressor motor is over heating and thermal protection shuts it down , when it cools down it restarts. Restricted air flow over the cooling coils could be the cause. Check filter,Sometimes furniture or other things block the return air vent.
Aug 27, 2014 | Heating & Cooling
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
While browsing net r watching movies my lap(acer extensa 4630)shut down itself
The processor has to perform large amount of work while surfing , especially while usingvideos and animationMultiple windows/tabsnumber of browserwhich in turn produces lot of heat . The heat produced is managed by the interneal heat sink and inbuilt cooling fans.But this cooling process may get affected by the blockage in air vents due to dust.So to safeguard the laptop form overheat, it automatically shuts down.
One simple try :Go to the Adobe flash properties and disable Hardware acceleration for online content. That ought to stop the system from rebooting or crashing.
Else...Its better to call a technician when it shuts down often.....
Apr 10, 2012 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
I have an Acer Aspire 5735. I use it everyday for my work, however over the last few months it has started to turn itself off. The fan starts to hum loudly for a few seconds and then it shuts down. I have...
The way you describe the problem, with the fan getting noticeably louder then shutting the computer down entirely, sounds like an overheating issue; the fan spins up to top speed to try and cool the system down, fails to do so, and the machine shuts itself down as a safety precaution.
Propping it up might have provided it with a bit more airflow, which may be why you experience the shut downs a little less frequently. I would invest in a can of compressed air, which can be found at any office supply store, and blow out the exhaust vents on your laptop. If you've never cleaned your machine before, dust and other debris that accumulates in the vents and around the fan have probably built up enough to restrict air flow.
Mar 08, 2011 | Acer Aspire 5735 Notebook
My acer extensa 5420 keeps shutting down like its over heating but i do not think it is over heating due to the fact i have 2 cool down fans on my computer(you set laptop on it and two fans blow on the...
Shut the system off, remove the battery and unplug everything. Blow through all the air vents with a can of compressed air. Keep blasting air in there until dust quits coming out. The reason I offer this suggestion is because it sounds like the system may be overheating, as you described. The cooling fans are great, but if the heatsinks get totally clogged with dust, the fans can't remove the heat as quickly. I don't know that this will fix your problem, but it's really easy and cheap to try, and a good place to start.
Feb 28, 2011 | Acer Extensa 5420-5687 Notebook
Our snapper shuts off after 15 or 20 minutes, does start back up after it cools - what do you think?
Could be the coil. Once it gets hot it shorts out and shuts the engine down then cools off and works again. OR it could be that the fuel cap doesn't vent and allow air into the gas tank causing a vacuum lock so fuel won't flow out of the tank. Just need to clean the fuel cap vent holes. Test for spark right away when it shuts down and still hot to find out if it is the coil. If the spark is gone when hot and normal when cold then it is the coil.
Oct 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Aspire 3000, shuts down after about 2 or 3 minutes. Doesn't seem to be too hot.
If the processor is not getting overheated, then you could have a faulty battery. Or possibly faulty power supply. You can test both with a voltmeter.
Oct 10, 2009 | Acer Aspire 3000 Notebook
ACER Aspire 5720 overheat problem?
Try to keep as much ventilation under the laptop as possible.
You can pick up a can of power spray and blow out the unit yourself or have a pro. do it for you.
Dust and lint play a deadly part in overheating with laptops.
Walmart has Ventilation trays in which the laptop sits and is cooled by forced air from underneath.
Make sure the direction of air flow is the same as your laptop.
You dont want to push air into a output vent.
Aug 30, 2009 | Acer Aspire 5720 6497 Laptop
Laptop goes off
If a computer shuts itself down suddenly after 10-15 minutes it's usually down to oveheating. clean the filters and ensure that there is good airflow around the computer when you use it. you can keep an eye on temperature and control your fans with this program
http://www.almico.com/sfdownload.php
you might need to buy a laptop cooler like this
http://www.amazon.com/Targus-PA248U-Notebook-Chill-Pad/dp/B0000AKA8Y/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1204562271&sr=8-1
which sits underneath it and blows cool air in
Mar 03, 2008 | Acer Aspire 5630 Notebook
TGDX64OEQ1 Gas Estate Dryer
Sounds like the hi-limit temp switch is sensing too high a temperature and is shutting off the dryer. This is a safety feature and is usually tripped because the outlet air flow is restricted, and resets itself after it has cooled down. Check to see whether the rest of the vent in your house is clogged and clean it. It could also be an inlet fan or blower which introduces air into the drum. If this is not working, there will be no air flow into the dryer, causing excessive heat in the non-moving air in the dryer.
Feb 01, 2008 | Estate TGDX640JQ Gas Dryer
Computers & Internet Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
