Question about Sony Cyber-shot DSC-W55 Digital Camera
SONY Cybershot lens keeps going in and out for like 10 sec
When i turn on my sony cybershot the lens keeps going in and out and it stops and on the screen it says turn off and on again but it doesn't work
I have a sony cybershot w-290. I downloaded pictures to my laptop from the memory stick. When I turn it on I get a message to turn it off and back on again. My lens keeps going in and out. I show full...
Sounds like your lens has issues. Probably some debris/sand got into it or maybe it suffered a
Jolt of some sort. Whatever the case maybe you will need to get your Lens serviced.
Sometimes if you use a case the camera may have turned on inside the case and caused
lens damage.
Feb 02, 2011 | Sony Cybershot Dsc-w290 W230 W220
The lens keeps on moving in and out and there is a sign on the screen to turn off and back on the camera... I have a sony cybershot dsc-w55
I have a cybershot DSC-P5 that was doing this. The plastic ring around the lens that is glued to the casing had become warped. We simply popped it off, brushed/scraped the excess glue away and put the casing back on, now it works fine! Just store it properly and keep an extra eye out for dust coming in where the lens used to be.
Jun 28, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
I have a sony cybershot and the backlight wont turn on
Jan 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My problem is i want a digital camera has 10 to 15 mega pixel cyber shot
I HAVE A SONY CYBERSHOT 5 MEG PIX WITH A CARL ZEISS LENS AND I LOVE IT IT OUT PERFORMS THE 8 MEG CYBER SHOTS
Mar 09, 2009 | Sony Cybershot DSC-T200 Digital Camera
My sony cybershot dsc-h3
Symptom shows your DSC-H3 has problem in Lens Mechanism and you need to replace complete lens.
If you want to replace it by yourself, Its part number is as follows...
A-1359-213-A LENS BLOCK ASSY
It is available in Parts Store on $150
Or contact nearest Sony Service Center for replacement.
Oct 12, 2008 | Sony Cybershot DSC-H3 Digital Camera
My sony cybershot dsc-p200 lense is stuck.
Sony Cybershot DSC-P200 worked great then the lens stuck in the open position.
Read on this site some one suggested gently manipulating the lens and tapping it then turning it on. It worked!!
Apr 07, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Problem*cybershot DSC-S40
You have a jammed lens error the lens has to be repaired or replaced. You dont have to drop the camera for this to occur it can happen when ever the camera is in your pocket or purse. it accidently gets turned on and when the lens is coming out it is obstructed and strips the little plactic gears in the lens.
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
584 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
