Question about Pioneer GM-X372 Car Audio Amplifier
Not working im hooking this amp up to pioneer 6x9s in rear of car. my deck is a pioneer also. i have pioneer front spekers to. the problem im having is when the amp turns on i get no sound trough any speakers and the red light flashes. if i disconnect the amp the front speakers work. i checked all my connections at least 4 or 5 times and even had a couple friends make sure my connections were right. i dont no what to do at this point can ya help?
  • 151 Answers
Make sure the remote (rem) port is powered, if not take another look at your inputs from the head unit as sometimes we tend to forget the channels orientation of ground and positive left and right.
If all else fails, have an audio installation expert help you out, a pari of extra hands would be helpful too...
Posted on Dec 09, 2007
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
How ot hook up speakers on this amp/
As far as I know, your sound will drastically improve if you run them +- and +-. Connect the one speaker correctly (+-) and then with the music still playing, try swapping the wires on the other speaker around and see which sounds better + to + or + to -
Hope this helps
May 20, 2010 | Volfenhag ZX-8300 Car Audio Amplifier
No sound from new stereo
check the speakers in the rear deck, in the rear hatch or trunk, often the two wires that come out of the speaker touch if that happens it will short out the speaker drivers in the radio most times no permanant damage will occur. separate the wires so they do not touch,or touch the metal speker base, that may not be the problem but its a start..
Oct 16, 2009 | Hyundai Motor 1998 Accent
91 oldsmobile cutlass ciera stereo wiring diagrams
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 3 1/2" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Thanks for using FixYa - A Good Rating is appreciated for answering your FREE question!!
Jul 07, 2009 | Pioneer Car Audio & Video
Car audio
Most likely the RCA's are running from the sub out on the deck to the amp. You need to run two sets of RCA's for a 4 channel amp. One for the sub out and one to the front or rear channel.
Hope this helps.
May 12, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Im just wondering what im supposed to have as options on the back of my deck. Im hooking it up to a sub and amp and just want to make sure im not missing any pieces
you should have to connections for your RCA's Some decks have 4 but that all depends on how many speakers you want to hook up in your ride
Apr 13, 2009 | Pioneer DEH-P6800MP CD Player
Alpine eq 3331 install
Mar 26, 2009 | Alpine ERE-G180 11-Band Car Equalizer
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
Dec 01, 2008 | Pioneer DEH-1600 CD Player
Additional speakers
does your stereo have additional outputs? you can get around that. anwser is: depending on the amp, yes you can.
Sep 20, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Pioneer GM-X372 Car Audio Amplifier Logo
93 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
