Question about Frigidaire Affinity ATF7000E Front Load Washer
Will not spin after wash and rinse - Frigidaire Affinity ATF7000E Front Load Washer
    Problem Solver:
  • 14 Answers
A lot of times it is the strainer clogged at the pump. Hope that helps. This has happened to mine in the past.
Posted on Sep 11, 2009
My beko wmb61431s will work in spin or rinse mode
check the clutch, the belt, the motor coupler, the door switch,
Feb 25, 2015 | Beko Washing Machines
Maytag MAH8700 AWM will not spin during rinse cycles
As you said in the question you are washing machine need to get services during rinse washing machines should spin.Try selecting only rinse option only.If it does not spin means just services it will be fine.Thanks for you are question.
Jun 17, 2011 | Maytag Washing Machines
Hello my washing machine has stooped... it will keep washing but will not rinse or spin out.. please help
sounds like you have aproblem with the lid switch , that will keep yoor unit from spinning after the wash cycle then it goes to a rinse cycle as long as the unit cant spin it then can't rinse.
Mar 10, 2011 | Estate TAWB600JQ Top Load Washer
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire Affinity ATF7000E Front Load Washer Logo
163 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
