Question about Vacuums
The dust bag inside the outer zippered bag keeps coming loose and making a HUGE mess. does it lock down or something? Wife is ready to throw the whole thing away.
    Genius:
  • 1,036 Answers
Hi
On most types there is a bayonet type fixing - 2 lugs that line up with 2 slots in the bag seal plate.
You usually need to rotate the bag 45 degrees to push the lugs into the bags plate, then rotate it so the bag is upright again.
This locks it in position.
When you have it working - clean the outer bag outside, as it will continue to throw dust out unless clean.
Posted on Sep 07, 2009
Outer Oreck xl bag is full of dirt
Make sure that your bag is pushed all the way past the lip on the connector tube and that the "U" shaped part of the plastic assembly is in it's slot behind that lip, or it will not seal properly and you will get dust into the outer bag.
Mar 21, 2014 | Oreck XL2200 Bagged Upright Vacuum
Blue plastic bag holder on oreck upright detached - how to put it back in?
Amy, not sure from your description whether the outer part is what came off or the smaller, inner part came off. If it is the outer part, all you need to do is squeeze the two prongs of the inner part of the bag holder together and slip the two pegs into the holes on the outer part of the holder. If the inner part came off then you have to spread it, so that it will go over the opening on the handle, and then follow the directions I gave to install the outer part. Hope this helps.
Feb 17, 2014 | Oreck XL Ultra Bagged Upright Vacuum
The bag will not stay attached it comes off the rubber nozzle and dirt gets everywhere my old oreck had a much better design with the velcro closure.i am very dissapointed.
Please make sure that the plastic pieces that holds the outer/inner bags on the vacuum are attached properly. Push the outer (permanent) bag down against the vacuum. It will go over a black lip. Put first piece of the bag dock on..make sure it is behind that lip also. When you reattach the second piece to the dock, this will tighten the docking system. It will keep the outer bag on and keep the inner (disposable) bag in place so that it is catching the dirt...not the outer bag.
Sep 23, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Having a terrible time keeping the bag attached during use. I am tired of cleaning the inside of the cloth zippered bag. I am using the correct Oreck vaccum bags, and using the metal clip that holds the...
I would Recommend getting a docking system. its $20 and takes place of the metal clip and ensures that the paper bag and outer bag both stay in place and to ensure no leakage.
Sep 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I have an XL Silver Upright Vacuum with a docking Station. Bag will not stay on and dirt & dust builds up inside the Vacuum. Big mess to clean out. Also vacuum is hard to push. Is it because BAG...
The docking station is not on properly...Make sure that you have the outer (permanent) bag pushed down over the lip of the vacuum. The docking system needs to be behind the lip also. This keeps both the inner and outer bag firmly attached. If it is hard to push, you may look into replacing the roller brush. They start breaking down..kinda like a toothbrush. It will make it extremely hard to push.
Aug 30, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I would really like to wash the outer bag of my vacuum, but I have a problem. I can remove the outer bag from the vacuum, but the plastic 'frame' that is inside the outer bag is sewn to the bag. So what...
you can wash the bag. However you cannot wash the bag in the wash machine. What you will want to do is look for the screw or depending on the model, untwist the cap down on the rod next to the machine. that entire pole section will come off of the unit below with the bag there.
I recommend if it is warm outside to use the garden hose to spray it and scrub inside the bag with a scrub brush and some dish soap.
I usually throw them into the laundry sink and let soak, scrubbing with soap and water.
To dry the bag, a hairdryer or hang to dry before putting the piece back onto the machine.
Good luck.
Mark
Nov 12, 2010 | Oreck XL2000 Bagged Upright Vacuum
Dirt smell
If this thing has a fast-spinning belt in the "head" of the unit, you are smelling the dust that is being collected in the back of the little drive "chamber" and is being heated up by the motor and the friction of the belt. This is a pretty common thing on vacuum cleaners designed like the Oreck. If it is huge bunnies of dust, well then that means there is a leak somewhere...
Mar 11, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Kirby
kirby style 2 bags if it is indeed a bagged unit, some where special order with what is called a shake out bag, if your outer bag has a short zipper with a cloth pocket it is a shake out bag in which you take the assembly loose from the machine and open the bottom of the metal empter and take out side and basically shake out the dirt. and use the pocket to help get out the dirt. but most of these machines did take a style 2 bag in which you unzip the outer bag and pull the paper bag away from the tube and reinsert new one onto tube and finally zip up bag
Mar 28, 2008 | Vacuums
No suction
1, Does the blower (discharge) side blow bunches of air??
Yes: Something is clogged from the bag to the hose end. Try blowing out the hose from the discharge side.
Or: The bag is not properly seated. Make sure that the plastic piece is properly inserted into the bag, and properly aligned and locked in place with the suction intake.
No: Something is wrong in the motor/fan assembly.
2: The hose has a plastic cover on the end farthest from the unit. Make sure that this cover is closed. If it is open, your suction will go way down.
Feb 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
