Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Machine will not drain all water at end of cycle
  • 17,970 Answers
Have a look into the bowl at the bottom. If there is a cover held by a screw on the left side, take the screw out, remove the cover and check for some debris blocking the impellor.
Be careful as glass is the most common item found in the impellor.
I hope help you with this. Good luck.
Posted on Sep 07, 2009
  • ZJ Limited
    ZJ Limited Sep 07, 2009
    Another steps to check the pump; If the water is not draining from your dishwasher, verify the following:
    - Verify
    that there is not a clog in the drain hose or air gap. This is
    typically the reason that a dishwasher won't drain and the clog is
    usually where the drain hose attaches to the garbage disposal or sink
    drain pipe. Remove the hose and clear any clogs, then reinstall.
    - Verify
    that water from the sink drain is not making it's way into the
    dishwasher. I would recommend creating a high loop in the dishwasher
    drain pipe, which is attached to the sink drain, under the sink. The
    high loop can be fastened to underneath the countertop. This will
    prevent any water from entering the dishwasher from the sink; it also
    prevents the dishwasher drain water from making it's way back into the
    dishwasher.
    Verify that the pumps drain impeller is working. You can
    reach the impeller from inside the dishwasher after removing the lower
    rack, spray arm, and arm support. This typically involves removing a
    few screws. Once upper parts are removed, inspect the drain impeller,
    which pushes the water toward the drain port, for any cracks or missing
    blades. If the impeller is defective, the water will not drain properly
    and you would need to replace it.
    Verify that the drain
    valve is working; many are controlled with an electric solenoid that
    opens the valve, sending the water to the drain. There is a chance that
    the solenoid or the diverting lever could be stuck which would prevent
    the water to drain. If so, try to free up the solenoid and lubricate
    the lever. Otherwise the solenoid or pump assembly may have to be
    replaced.
    Verify that the motor is turning/ working and
    Verify that there is power to the motor. If the motor hums but doesn't
    turn, it may need to be replaced. Motors can get stuck if not used
    regularly. If the motor is defective, the water will not drain and you
    There are ways to test the pump
    and motor with a multimeter. If you are not comfortable with doing
    this, you may want to have a technician test it for you.
    Good luck.
  • ZJ Limited
    ZJ Limited Sep 09, 2009
    Have you removed the filter?
    If it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump.
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
I purchased a new washing machine, Samsung SW50V3WFP, this is top loading washing machine. Problem: Water is draining out from the machine from drain hose, I cant fill water in machine to wash after...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jul 02, 2011 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Water not draining
It must have drained water out at some stage because it got to the end of the cycle.It sounds as though the pump may be blocked.The pump can be gotten to by removeing the rear panel on the back of the machine,make sure the machine is unplugged.water will come out so first try syphoning the water out of the machine.if the drain hose comes out from the bottom of the machine then just lay it down into a bucket to get the water out.
Jun 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water leaks when draining
sounds like the drain pump is leaking
Feb 21, 2010 | Washing Machines
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
Water does not drain from machine at end of cycle
it sounds like the out flow is blocked some where on the front of your machine normally down the bottom there is a door open it behind should be a tap/plug type of thing turn it but put something underneath to catch the water this takes time when done take the plug out all the way have a look at the fan behind it will probably be blocked
Aug 21, 2009 | Asko D1716 Built-in Dishwasher
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
135 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
