Question about Hitachi 43UWX10B 43" Rear Projection Television
The color is not quite right now. Ther are a few waves of purple and green.
  • christy_p922 Sep 08, 2009
    Can't find the convergence in the menu. We lost the remote, but can access the menu from the buttons on the t.v. Is it in the sharpness menu, that's the only part of the menu that talk about the color. We tried the magic focus and no change. Some of the areas that have the purple and green are also duplicating the picture.
  • SD Tech
    SD Tech May 11, 2010
    1. This sounds like a convergence problem. 2. Try to go into the customer menu and with the remote see if the convergence will or will not adjust. 3. If some color (red or blue) will not move in some direction--you have a bad convergence chip. 4. Confirm that model number is 43uwx10B and I will tell you what is needed to fix the set. SD TECH
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
1.)This kind of trouble happens for a reason. The two convergence chips have a metal back and are bolted to either one large or two smaller heat sinks to keep them cool---a white grease is applied to the back of each chip to move heat fast---after some years the grease dries out and a chip reaches a point where it cannot move the heat fast enough and it goes.
2.) You can locate the chips inside the set--they are black, 2 1/2 inches wide and about 1 1/2 inches tall with the STK number printed on them in white--most of these sets use either STK-392-110 OR STK-392-150 CHIPS---the 150 chip is a higher current and longer lasting version of the 110 chip. You can buy a pair of these chips on Ebay for less than 13 dollars plus shipping.
3.)The chips have 18 pins each and need to be unsoldered to replace them----Most of the time you just need to replace both chips and adjust the set with a remote control---I did two Friday---takes about a hour to do this repair.
4.) I do not know what level of skill you have but if you can do this yourself--you will save some real money--once the chips are replaced and the set adjusted--it will not have this problem again for 5-8 years---about the only problem this kind of set has.
5.) If you cannot do this look for someone in your area who can do this---some shops will TRY to charge 300-400 to do this repair--I have done hundreds of these sets and here I charge 200-250 total cost.
6.) If you call and they say it "has to go to the shop" keep looking as any good tech can do this repair right in your home.
7.) Now is the slow time of year for TV repair shops--shop around and make SURE WHOEVER DOES THIS REPAIR CHANGES BOTH OF THE CHIPS---if only one gets replaced you will have the same problem again and soon.
8.) Yes, sometimes there will be a bad resistor or two damaged by one of the chips---no big deal--any good tech will be prepared for this.
9.) If you have ANY QUESTIONS OR NEED HELP LET ME KNOW- I am here to help people.
10.) I do this here for free so if this information has helped you take a minute and give me a vote here. Remember, IF you have questions just reply to this post here and I will try to help or advise you.
Regards, SD TECH
Posted on Sep 08, 2009
  • 80 Answers
Needs new convergence chips, part number is stk 392 -110, they need to be soldered in, also there might be some burnt resistors around the chips, you need to visually inspect them. you need solder skills and disassembly ability. might need a tv repairman.
  • daniel tucker Sep 08, 2009
    the magic focus is your convergence adjustment, it is electronically adjusted and if the magic focus doesn't clear it up you definately need new convergence chips, this is one of the more trouble free models, convergence chips are all that ever go wrong, but no amount of adjustmentsa are gonna help, if you don't get the chips replaced it won't work.
Purple and green injectors for mazda protege 2003
Green is for cylinders 1 and 2, purple is for 3 and 4.
Jul 27, 2013 | 2003 Mazda Protege
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 07, 2010 | Car Audio & Video
I have a fairly old panasonic car stereo/cd changer. i just need the wiring diagram for it. what color equals what? i typed in the model number but nothing turns up. . . i had to replace the old system,...
Here is the Colors of the Cars factory harness
Constant 12V+ Red Switched 12V+ Red/White Ground Black Illumination n/a Dimmer Orange/White Antenna Trigger Yellow Antenna Right Front Front Speakers 3 1/2" Dash Left Front (+) Green Left Front (-) Green/Yellow Right Front (+) Purple Right Front (-) Purple/Yellow Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Brown/Yellow Right Rear (+) Blue/Red Right Rear (-) Blue/White
And Here is the Chart for the radios wiring
Red 12V+ Switched power
Grey Right front speaker +
Grey with black stripe right front-
White left front +
white with black stripe l/f -
Purple R/R +
Purple with black stripe R/R -
Green l/r +
green with stripe l/r -
Black ground
orange illumination
yellow constant power
Need wire colors power,ground,speakers/clarion arx6670zterryrose
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Oct 12, 2009 | Clarion ARX6670Z Cassette Player
Need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
purple right rear +
Aug 25, 2009 | Sony CDX-F5710 CD Player
My T.V. has a funny color .. more of double viewing with purple and green what can I do to fix this?
Your set has a problem with its convergence circuitry. In many cases this can be simply failure of solder connections to the output integrated circuits due to the heat they generate, and resoldering them fixes the trouble. This is a repair you might be able to try for yourself if you have experience with electronic soldering. Or there might be component failure which would require the equipment to isolate and replace the bad parts, which is a repair level best left to professionals. In some cases where the set has digital convergence, the failure might be in the computer control portion. This means the repair might range from only a very few dollars in parts to quite a lot of dollars, plus whatever labor rate the servicer charges. If you aren't looking for an excuse to replace the set, getting an estimate on a professional repair would be the best suggestion.
Degaussing is deliberately applying a magnetic field to the face of a picture tube. This is done to neutralize the effect of other magnetic fields that can cause color distortion. Degaussing isn't done in projection sets because they have separate tubes for each color.
Dec 16, 2008 | Toshiba 50H81 50" Rear Projection...
Reinstalling into new vehicle looking for wiring color codes?
yellow (memory 12v+) red (accessories) black (ground earth) blue (power antenna) blue (amp rem) white with stripe (left front speaker + white( left front speaker - )grey with black stripe (right front speaker + grey (right front speaker -) green with stripe (left rear speaker+) green (left rear speaker -) purple with stripe (right rear speaker +) purple (right rear speaker-)
May 25, 2008 | Pioneer DEH-1000 CD Changer
No installation guide for deh-p6900ub radio
grey-right front +
grey/black-right front -
white-left front+
white/black-left front-
green-left +
green/black-left rear-
purple-right rear +
purple/black- right rear-
Mar 28, 2008 | Pioneer DEH-P6900UB CD Player
Hitachi 43UWX10B 43" Rear Projection Television Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
