Question about Maytag Neptune MDE5500AY Electric Dryer
Is there supposed to be a hole on the side of my dryer
All of the sudden there is lint coming out of the side of our maytag neptune dryer has it always been like that
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 88 Answers
Well, though it be simple, you might clean the lint filter everytime you use it. Over time a dryer even with lint filter cleaned will still collect small amounts of lint inside it. You shouldn't worry much but you could call the maytag man to come and take apart the dryer and clean the inside. <;O)
Posted on Sep 07, 2009
Maytag Neptune Gas Dryer MDG 5500Aww Dryer runs and heats when cold, then after about 5 minutes the flame cuts off, after a few minutews, the ingiter glows red, but the flame does not come on again unless...
Hi!!
I seems like you have a plugged up filter and/or an obstruccion in the exhaust hose/pipe.
Remove and clean lint filter, also remove exhaust hose/pipe from back of dryer and remove any lint accumulated. Check also the exhaust hole in the dryer.
Don't forget to rate this post. Good Luck!!
Jul 06, 2010 | Dryers
NO HEAT NEPTUNE MCE8000AY MAYTAG
First begin by pulling away from wall. Unplug and begin by checking for 240 coming from outlet. We will need a multimeter to check ohms and test points along the way. Most times people do not answer so I will leave some information and will pick up on your case when you respond. Fact is I had a service call on one like yours. The lint filter had a hole that allowed lint to collect in the exhaust to the point that moisture collected in the lent blocking ventilation. I know you said you checked yours, but we need to find where the power stops, door switch, thermal overload, etc. Those dryers are a trick to open, I will be around later if you would like my assistance, Thanks, Sea Breeze
Jan 21, 2010 | Maytag Neptune MCE8000AY Electric Dryer
I have a maytag neptune dryer and there is always build up under the lint screen area. I am wondering if there is supposed to be a seal aroound the lint screen itself as mine has never had one??
I have one and there is no seal. I just stick the vacuum cleaner in there every so often or use the fluff from inside the lint screen to give it a wipe out, it likes to stick to itself.
Nov 26, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is not heating all the sudden. I just
check and see if the iginter is loose or not making good contact
Oct 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Can't find the lint cleaner
In order to locate the lint filter for your dryer you must first remove the door. to do this first open the door and remove the screw that hold the hinges to the front of the dryer. once the door is off. there are 2 screws at the bottom of the front access panel. once the screws are out the panel will come off of its brackets by pulling the bottom out first. once this panel has been removed you will be able to see the inside of the dryer and the lint screen is directly behind this panel on the LEFT hand side and it will just pull straight out. if you need a new one the part number is 33001808.hope this helps
Thanks
Oct 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer lint throughout thr house
lint throughtout hte home is a sign tha there is a tear / or a disconnect of the dryer vent. check your venting
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doioesn,t dry in a 90 minute cyclr
you need to clean out the back vent hole on the dryer and the wall vent,you are keeping the moist hot air in the dryer that needs to be vented out so the dryers not drying like it should,let me know how you do-mike
Nov 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
MayTag Neptune MDG9700AW Gas Dryer
Check the lint tubing and also for lint underneath the dryer. There is a blockage somewhere for this to happen. This is a built in safety feature for gas dryers that others don't have.
Jun 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
81 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
