Question about Kodak EASYSHARE 5100 All-In-One Printer
Constantly runs out of ink
By calling tech support found that the printer uses ink when not even printing!! this printer does not save on ink. Total junk!!
Hp envy 5530 printer prints half way and stops
Please download and run the HP Print and Scan Doctor from Find and Fix Common Printer Problems Using HP Diagnostic Tools for...
If issue still persists and if you have subscribed for Instant Ink, then please call HP Tech Support for further assistance.
Apr 27, 2014 | HP ENVY 5530 e-All-in-One with 2-month...
Parts inside your printer are coming to the end of their life
It could be the Waste Ink Pad. Call Epson tech support for the correct answer. If it is the pad go to the site below and get a Waste Ink Container. It sits outside the computer. Lood at the CISS, it will save you Tons of money.
http://www.inkproducts.com/ink-store/
Aug 04, 2009 | Epson Stylus Photo® R800 InkJet Printer
Printing problem with Epson CX9400
I have a CX9400Fax and occassionally print is mixed/missing lines. You must do a Cleaning cycle usually at least 4-6 times or until it prints a clear pattern. It will use LOTS of ink during the cleaning cycle. The printer normally uses a lot of ink, my solution was to purchase a CISS system along with a Waste Ink Container. IMO the best CISS is sold by the company below. I did have to call for tech support once and they returned my call in 30 minutes, problem solved and never came back. I purchase refill ink and it seems that I do a lot less cleaning cycles.
Jun 20, 2009 | Epson Stylus CX9400 Photo Printer
Dead print head
the reason why the printhead is going bad is because this was a problem with the printer since it was launched since day one all tech support will do is replace the print head but if u call them and ask them to escalate the case to a manager and you need to act very irate then maybe and just maybe you should get a refund.
the printhead keep rubbing against the bottom of the carriage in this printer causing the contacts to wear off really fast and thats the problem ur facing ,it was one factory faulted printer that was launched
Jun 19, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Everything that I print is faded with lines through it.
This is the same problem I have with my Kodak ESP-3 printer. Even after installing new cartridges I had faded color and lines (banding) thru the picture. I found many people wit the same problem and found out that Kodak had a very large batch of defective printer heads that were sent out with the ESP and 5500 series printers. I called Kodak customer sevice, the automated systym even has a number to push for the problem printers. Then you get a live tech person who runs you thru some diognostic steps. They are well aware of the problem and will send you a new printer head and cartidges for free and they pay the postage.
Jan 29, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP3 will not print over half of the time.
all you guys i know you are all frustrated but m just trying to be helpful to you all............First thing there are lot of compatible and look alike and refilled ink cartridges available for the kodak printers which actually screws the printer........i have the whole list of numbers on the ink cartridges which are genuine and i can give it to you all if you want........to fix your issue just try and do the print head cleaning from the home center software on computer to which this printer is connected......if still the same issue then just call kodak tech support as its a print head issue.........
Dec 24, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Awfull looking pictures & copies
It seems that this printer has issues, I called the number below and went through a few steps with them, my issue was the black printing and the printing of pictures being red.. they are sending me a new printhead...this might just be the issue
Troubleshooting with the Kodak tech (1-800-421-6699 US & Canada)
Aug 18, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Epson 1400 wet black blocks of ink output
When this happen it means that your Fuser assembly and printer interior has toner contamination and build up. You can replace your fuser or run some more test print. Usually, the printer corrects itself.
Jul 26, 2008 | Epson Stylus 1400 InkJet Photo Printer
Canon MP830 - extreme ink useage
According to a service manual for a similar Canon printer, the grayscale printing should only use the Pigment Black ink PGI-5BK.
On fast it is 300x300dpi with 1 pass, standard is 600x600dpi with 1 pass and high is 600x600 with 4 passes.
On plain paper in colour it is meant to still only use the C/M/Y and again the big pigment black ink PGI-5BK, it only uses the smaller black ink once you set it to use a photo type paper in the printing settings.
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cyan cartridge not working
You have to replace the cyan cart with a new one. error should disappear.
Even though you didnt use cyan the machine needs some ink to keep the noozles wet. Therefore machine does some automatic cleaning cycles which consumes some ink.
BTW: did you program the date/hour settings? Do so and do NOT disconnect machine from constant power, because data will be deleted. machine will do its cleaning cycles about every 2 weeks. otherwise it will do the cleaning everytime its powered up!
Dec 12, 2007 | Brother MultiFunction Center MFC-440CN...
Kodak EASYSHARE 5100 All-In-One Printer Logo
24 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
