Question about General Electric Microwave Oven
I have a GE over-the-range microwave model jvm1430wd002. Nothing works, not even the light nor clock. Fuse not the problem. ????? >ed
  • GE Master
  • 9,047 Answers
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
The TCOs you need to be concerned usually with have thick black or white wires only.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly if you need more FREE help & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
GE Model # JVM7195SFSS microwave.
Check the internal ceramic fuse on the circuit board. Sometimes one section will work while another won't. I'm not sure if this model has a rear mounted thermal fuse, but the models with the inline thermal fuse will cause a similar issue.
Jul 04, 2014 | GE XL1800 1100 Watts Microwave Oven
I have model # JVM1430WD002. Both the under light & ventilation fan are not working. When I press the button, I can hear a click but nothing comes on.
Sounds to me like you main control board is failing. The relays on the board that control the light and fan are closing but the points in the relay are probably burnt and not making contact. You will probably need to replace the main control board. Hope that helps.
Aug 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How to change fuse on je2160sf02 ge microwave
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
I would also suspect the thermostat associated with your magnetron.
Feel free to contact me directly (and please remind me of your full model number) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
May 27, 2010 | GE JE2160 Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to open GE microwave and check fuse?
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 02, 2010 | GE JEM31 Microwave Oven
I've replaced the fuse three times in my GE over the counter microwave. The clock, timer, lights work, but when I put something in the oven to heat, it immediately blows the new fuse. Is there something...
NO, MW can be LEATHAL.. If a fuse is blowing that means that you have a Phase to Earth fault BAD. In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.Yes they are right.
Jan 28, 2010 | GE Profile Spacemaker Over-the-Range...
I own a GE over the range microwave, model #HVM1540DN1BB The touch panel doesn't work at all. I can't even set the clock. I even umplugged it for a couple of DAYS, and still nothing. I called GE, and they...
This model from GE is a ****..they replaced the keypad once wihtin first 2 months..now just after warranty..same issue again. Never buy GE products. The replacement key bad is $44+shipping in many onlne parts store..I am giving it one more try..next time this happens..GE will be out my door!!
Dec 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave Model JVM1450 It's been working great. Then put somethingin,turn it on. It ran 30sec. made a growling sound,like it was straning or slowing down,then Blew the fuse.I replace the...
SOUNDS LIKE MAYBE HIGH VOLTAGE RECTAFIER SHORTED MIC ARE VERY DANGEROUS THEY HOLD VOLTAGE EVEN WHEN UNPLUGED YOU MAY CONSIDER PRO ON THIS SORRY
Nov 06, 2009 | GE Microwave Ovens
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
156 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
