Question about Home
Basement toilet won't flush. water fills the bowl and tank fills back up...but toilet doesn't flush
  • 2 more comments
  • skipkeltner Sep 09, 2009
    we are on a municipal sanitary system
    we have a 2"pipe to a sewage ejector in another room about 10 - 15 feet from the toilet
  • Steve Allison
    Steve Allison May 11, 2010
    Kind of important too; are you on a municipal sewage system or septic?
  • Rod Davies May 11, 2010
    Look at the back of the bowl. Do y have a 4" pipe which goes out of the basement or do you have a 4" pipe which goes into a 'Saniflow' type of box which then has a smaller pipe to the outside
  • 62 Answers
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Posted on Sep 07, 2009
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
Not enough water goes into the Toilet Bowl, The Tank fills up fine but very little goes into the Tank, Terrible Flush
THERE ARE LOTS OF SMALL HOLES WHERE THE WATER COMES OUT OF IN THE RIM OF THE TOILET BOWL, SOME TIMES HARD WATER BLOCKES THES AND THEY NEED TO BE CLEANED. THEY CAN BE CLEANED USING A LARGE SEWING NEEDLE, PUSHING IT INTO THE HOLE UNTIL IT FEELS A BIT BIGGER, YOU WON'T DO DAMAGE AS IT IS VERY HARD METERIAL. a
AFTERWARDS TURN OFF THE WATER, AND LIFT THE VALVE AT THE BOTTOM OF THE TANK AND PUT SOME TOILET ACID INTO IT. THIS WILL ALSO HELP CLEAN THE HOLES.
May 22, 2012 | Kohler Toilet - One Piece with Ingenium...
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
My flapper was leaking, so I replaced it. Now, when I flush, the water leaves the toilet bowl, fills the bowl, and wants to flush again. All the water wants to leave the tank, but the toilet doesn't...
Reset the fill valve so that it does not fill the tank so full....this will be easier then trying to find a different flapper that will drop down faster, which is the only other thing you can do...
heatman101
May 15, 2011 | Plumbing
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Jan 29, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
I flush the toilet, tank fills up and cuts off, but the water leaks out, then the tank cuts back on to fill up and this is a vicious cycle.
Go to the hardware store and get a new flush valve flap made by Korky and install it. Your flush valve flap has worn out and allowing water to leak through.
Oct 12, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
Basement toilet drains slow sometimes ,other times doesnt want to go down all the way. seems as if there is no pressure to remove waste
if the toilet is old or not cleaned proper, the water jets that shoot the water into the bowl might be clogged. If the jets are clogged with moldor hard water build up the toilet will not flush proper. If you can take a 3 gallon bucket of water and pour straight into the bowl and it flushes fine you have a water pressure problem as described above. the problem also might be that your water inlet system is not letting in enough water to fill the tank. If this is the problem you need to replace the water inlet mechanisim, such as a fluid master. If you use a blue water device that hangs on the side of the tank in the back of the toilet you might have a peice of it under the flapper that takes the water to the bowl when being flushed. Check under the flapper if you put cleaners in the tank.
Mar 23, 2010 | Crane Plumbing Toilet To Go Tall...
When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Oct 31, 2009 | Home
Bowl will not fill.
There is usually a small tube on the top of the ballcock or the fill valve in the toilet tank. The tube should be clipped to the top of the flush valve pipe so that the water will flow into it. Should the small tube become loose and fall off of the clip, the refill water will not make it back into the bowl.
Aug 09, 2009 | Home
Home Logo
956 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
