Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
The freezer is full of ice - Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
if your freezer is not a frost free then there will be having an option defrost button in the freezer so check it and press the button. the ice will melts.to prevent this in future please check the freezer after every week and press the defrost button.
Posted on Sep 13, 2009
Every time ice maker runs, water accumulates at the bottom of the fridge. It is a bottom freezer model made 9-2013. What could be plugged?
Check the ice maker fill cup, it could be full of water or ice and all the water misses the ice maker. Check the fill line in the freezer to make sure its in the full cup to the ice maker. CHeck the drain under the evaporator in the freezer to see if it is open and obstructed. Thats what I would look for. Good Luck
Apr 20, 2016 | Refrigerators
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
My gsl25jfxblb GE side by side ice maker won't stop making ice. It overflows out of the bin and fills the shelf below with ice. Then when we open the freezer door to remove some food, ice spills...
no idea yet but many years back we had one that froze my wifes feet at 5:30 am when she opened the freezer to get ice for coffee and the freezer was full of water .
Mar 20, 2015 | GE Refrigerators
How do I control the amount of ice in the freezer? When I open the freezer door ice pours out onto the floor and in the freezer itself.
That is going to a internal problem in the icemaker,is has a sensor that when it detects that the ice bin is full its supposed to cut off the icemaker so it doesnt overflow and continue making ice such as your experiencing. By replacing the icemaker it will shut off when the storage bin is full.
GENE
Sep 26, 2011 | Refrigerators
How do i get the ice maker to make more ice?
Set freezer temp to lowest number, use "ice plus" feature. (it goes back to non-ice plus after about a day on it's own though) Dump excess ice into freezer storage bin if it gets full to keep it making more ice if needed.
Sep 25, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Nov 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
