Question about VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - White
We have a broken tank lid and need to replace it.
    Scholar:
  • 150 Answers
Try your local plumbers merchants [u need the make of the toilet] or thy local salvage yards www.salvo.com could be helpfull
Always take the broken lid with you
Posted on Sep 07, 2009
, Hi good evening ,i need the lid tank for toilet tank 4440
Amazon lists one:
Product Description
Briggs - China Toilet Tank Lid for use on tank #s 4420, Altima 4430, 4433 and Abingdon 4440 tanks. Click here to buy now. Same day shipping on most orders. High quality construction. Quality Replacement Part.
Briggs China 7469 130 Toilet Tank Lid
Feb 01, 2015 | Home
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
there is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Mar 14, 2011 | Summit Appliances Division Mansfield 386...
Broken Tank Lid
the model # is inside the tank. take that number to lowes and they will order you a new one.
Dec 04, 2010 | American Standard 4110 White Toilet Tank...
Water does not get hot
There are several things that could be causing this - the thermostat, the limit thermostat, or the tank heater itself. You can start checking by unplugging the unit, then remove the screws from the lid. Carefully lift the lid until you can reach the wires going to the top burner. Pull these wires off, placing them where they won't make contact with the metal on the unit. Look inside the unit, and see if there are any wires burnt off. If not, look at the small limit thermostat that is located on the top of the tank. It's a little round white unit. Move it around, and see if it's loose or broken. lift the metal tab, and take the limit thermostat out. Many of these units break apart, and quit working. If it's broken, take the two wires off it, and replace it. If not, then it will probably the thermostat or the tank heater. To see which it is, take the wires off the tank heater -the two poles sticking out of the tank lid. Using a voltmeter, check for resistance across the two poles. There should be resistance there. Also, check for continuance from the heater posts to ground by placing one lead on the heater post, and touch the other to the side or top of the tank. If the needle moves at all, your tank heater is shorting to ground, and needs to be replaced. If these tests are ok, then the main thermostat needs to be replaced. Hope this helps.
Apr 30, 2010 | Bunn VPS Coffee Maker
Toilet lid is broken, is there a way to find a replacement
Any normal toilet seat may work, check your local Home Depo.
Mar 23, 2010 | VitrA Aria Toilet with Round Bowl /...
Kenmore elite not spinning
This issue is caused by:
- Lid open. Be sure the lid is correctly closed
- Lid switch broken. It may need to be replaced.
- Motor broken. QUite expensive repair, the motor needs to be replaced.
- Timer broken.
Check the lid is correctly closed, perhaps the lid switch is having some failures.
Nov 05, 2009 | Kenmore Washing Machines
BROKEN fUEL TANK EXTERIOR METAL LID
Just the metal lid is available through the dealer for about $25.00 Part # 63910-S02-A00ZZ. However a new lid comes in black primer and would need to be painted, this would cost approx. $50.00
A 2000 civic is a pretty common car. If you call a few salvage yards in your area, I am sure that someone will have one in the color you need for about $25.00 +shipping.
Sep 10, 2009 | 2000 Honda Civic
Hoover SteamVac Model F6056-900 SteamVac/SpinScrub. Indicator light and high pitch suction noise indicates that dirty water tank is full. However, water level indicator (yellow bobbing plastic thing) is...
There are 2 filters, make sure they are clean, one is on the tank lid, the other is from the bottom, it is red, pull it out and clean it. If yours has a foam filter on the tank lid covering the yellow ball, make sure there is at least a 1/4 in. gap from the top. Also make sure that the lid in on and secured tightly.
May 26, 2008 | Hoover Vacuums
VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - White Logo
270 people viewed this question
Top VitrA Home Experts
jasbo
jasbo
woodzowl307
L Pfaff
L Pfaff
Are you a VitrA Home Expert? Answer questions, earn points and help others
