Question about Samsung SCX-4500 Laser Printer
I am having the similar problem with my scx 4500
Its 1 month out of waranty now. All I can see is the blue standby light is lit all the time with a constant buzzing (moaning) noise. Could somebody help me out please? Thanks
Scx-4500 power led hold on
Read the message then appaire on display and contact me.More details.
Feb 14, 2013 | Samsung SCX-4500 Laser Printer
I have a samsung wep 450 and lost the phone it was paired with, is there a way that i can rest my blutooth so i can pair another phone to it?
In order to pair your headset with another phone you have to put the headset into pairing mode. You can do this by: Turning off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. Search for and pair with your phone according to yourphone's user guide. (Bluetooth PIN: 0000, 4 zeros) If the pairing is successful, the blue indicator light willflash 10 times rapidly before entering Standby mode. If the blue indicator light remains lit, retry pairing.
Jul 15, 2011 | Samsung Televison & Video
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Lost instructions for how to get my cell phone connected to my samsung mep 350 calls for pin and i dont have one
• Turn off your headset and press and hold the Multifunction
after blinking.
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
Jan 03, 2010 | Samsung WEP350 Bluetooth Headset Red
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
Technika lcd32-207 is stuck in standby. Blue standby light dims.
Hi brendafoud, have you had this fixed as mine is the same and has been for months. It happened just after the warranty had ran out(typical). Bought from ebay and the people I got it from are not very helpfull. Have you got yours fixed yet?
Jul 09, 2009 | Televison & Video
Printer won't work
You got a 12 month warranty, use it !!
Jun 27, 2009 | Samsung SCX-4500 Laser Printer
Samsung SCX-4500 Laser Printer Logo
273 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
