Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
My whisper quiet dishwasher is not cleaning the top rack dishes
The dishes on the bottom rack are coming out clean,but the top rack is not getting any water therefore the dishes on the top come out filthy.Im finding this very frustrating.Any ideas?
  • lasaulnier Sep 27, 2009
    Im having the same problem,have you heard any ideas on how to resolve the problem?
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Posted on Mar 05, 2010
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
1,273 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
